m00dawg Posted August 18, 2008 Posted August 18, 2008 Super elementary question, I know. I'm pretty sure I know what it does, but the description on ucapps.de, the forum, and even on x0xb0x (the Adafruit TB-303 clone kit) doesn't seem to help explain what the MidiBox CV, or more particularly 'CV' is for? I assume it is basically a way to do analog filtering? So the MidiBox CV, is basically then a generalized filter box? If so, I assume that it would be an alternative to adding a low-pass filter to, say, a MidiBox SID directly right?Can someone maybe clear this up? Or tell me where I can go for a clear "idiots guide to CV" description? :)
bugfight Posted August 18, 2008 Posted August 18, 2008 cv == control voltage.with the midibox aout module you get 8 cv outs, which can be used to control anything that takes a cv input, for example a modular synth, or an analog keyboard or expander or or...the midibox cv is an application that implements midi control of the aout (as well as some other goodies).so it's not a filter, but you can control filters with it...
m00dawg Posted August 18, 2008 Author Posted August 18, 2008 *OH* ok so now that makes a ton of sense! Thanks to both you guys! I have no analog synths so I assume, then, that I don't really need a MidiBox CV :) But still want to eventually make a filter for my SID (once it's more functional anyway).
