codydjango Posted August 25, 2008 Posted August 25, 2008 I have no clue. everything is the same. it was working fine, but now notes will hold, or the wrong notes will play; i checked the wires and they all still seem to be properly soldered... any ideas?thanks
/tilted/ Posted August 26, 2008 Posted August 26, 2008 What have you changed? Something must have changed to get different results.It could be something obvious, like a cable, or a controller, or something a little more subtle, like you turned the case over... or mounted something new into the case.We could always start with the basics:What are you building?What point are you at?Not a lot to go by in your question...
DenDer Posted August 26, 2008 Posted August 26, 2008 any ideas?thanksNo not really :) more info please.
