whomper Posted September 5, 2008 Report Posted September 5, 2008 First, sorry about posting on this board, I could not find a Midibox CV usage board...When working in Mono mode for a channel, pressing and holding one key, and then pressing another key (while the first one is being held) does not produce a new Gate trigger. From my experience with Mono mode, each and every key press will trigger a new Gate event even if other keys are still being held.Is there some configuration I am missing?
TK. Posted September 6, 2008 Report Posted September 6, 2008 So, it behaves like Legato mode?This re-trigger in mono mode is quite short (ca. 1 mS), it could be that your analog synth doesn't get it. There is currently no possibility to increase the delay of the re-trigger eventBest Regards, Thorsten.
whomper Posted October 10, 2008 Author Report Posted October 10, 2008 There is currently no possibility to increase the delay of the re-trigger eventanything that can be considered for a future software release?
doc Posted October 13, 2008 Report Posted October 13, 2008 This re-trigger in mono mode is quite short (ca. 1 mS), it could be that your analog synth doesn't get it. There is currently no possibility to increase the delay of the re-trigger eventJust an (unfinished) idea:If the synth won't get this short trigger, maybe a "analog" solution may help.What about this:Put the trigger signal in an op (wired as impendance follower) to stabilize it and then make it a bit longer. Don't know how. Maybe just with a cap/resistor (mabe in combination with a 74HC00) at the output of the impendance follower. As said. Just a quick idea.greetsDoc
