I looked further and i found the following plug on www.reichelt.de :EBS 63P.
Can someone confirm this is a correct jack plug.?
Observe difference in the pins - this jack would not fit flat against the PCB. Although if you had no other choice, you could buy these and trim the pins with wire cutters.
That is exactly what I did with exactly that part exactly five minutes ago. Works more or less fine.
Think that's the wrong part # for mouser. I looked up the manufacture code. And i'm getting mouser part # 550-20301.
Why Mouser has two different Manu codes for Neutrik is anyone's guess, but the main difference I see between your part and mine is that mine has kinked legs so it snaps in place on the board.  In fact, both are on the same page of Mouser's catalogue.
But I recommend the NYS216.
