Durisian Posted October 16, 2008 Report Share Posted October 16, 2008 There's a few pages in the wiki that deal with using the different pic types that are outdated/incompleteI propose removing these pages and adding a new page that deals with the details of the 3 supported PICs and using them under the MIOS programming platform.Is there any docs about 'using' the new platform yet? Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 16, 2008 Report Share Posted October 16, 2008 Tidying up the existing doco is a big job (often as big or bigger than the task of nameing it), but when done right, it's a really good thing. I usually do a cleanup binge whenever I see something that's getting messy, so I encourage others to do likewise... and of course no changes are final on a wiki, so if you make a mistake, then it can always be fixed ;) Go for it!I like the idea of a single page which covers the three (and more) PICs which can be used. Not sure how much detail can go into it, but it's a good idea.Tips: Remove everything that's duplicated or outdated. If you remove outdated stuff, replace it with new info, and put a pointer to the old info there, so that if people find old info, they'll know to ignore it when they read your page.Follow backlinks when you remove a page, so that you can update links to your replacement doco.Search the forum for corroborating info. You don't wanna put the wrong info on there and get egg on your face when someone screws up because of your words :)Search for similar pages to the one you're working on, and follow links from it. If you find one little bit of mess, chances are there are related messes that should be cleaned at the same time. OK You've opened a can of worms.....There are no new platform docs as such, just the /doc/MEMO file on SVN to get the devs started up. However, if you're thinking of doing a *really* big tidy-up, then perhaps it should be considered to start arranging the files in a manner which 'makes room' for the new stuff when it's time to put it up there...Ther are other things which could do with some attention, from memory: Like our three FAQs ;D something needs to be done there... and the blurred division between 'end-user' and 'developer' targeted doco should be removed too IMO.... Unless you're building a TK-clone or a wilbasid, "development" - to some degree, if only something minor like changing the number of pots in your controler, is unavoidable. In general, I think that the doco could do with a more linear structure. The #1 request for doco, by country mile, is a "start to end" tutorial on building "something". Of course, there are large amounts of duplicated documentations involved in doco like that - for example you don't need to explain how to build a core for a clockbox *and* a MBCV - it's the same thing.If you view it from a distance, the beginning and end of the wiki should be the same for all projects:Beginning: Welcome to MIDIbox.org!End: Enjoy your song!Everything inbetween, can fit into a sort of cigar-shaped structure, where topics branch out for specifics, and then re-merge where the split topics are no longer necessary.I toyed with some layouts like this in visio flowcharts and it was looking pretty good, but it's a big ass job, so I've been sitting on the idea until the new platform doco is ready. Seems like an opportunity to bounce the ideas off you guys ;) Quote Link to comment Share on other sites More sharing options...
Durisian Posted October 16, 2008 Author Report Share Posted October 16, 2008 mmmmmmmmmm... wormsok.... so... ... yeah, wormsI think your right, we need an overview of the whole thing before it can really be cleaned upmaybe we need a 'how to build a ...' templateIntro-All about it, what it does and blahSkills / Equipment RequiredTools - linkSoldering - linkHarware-list of modules - with links to how to build them-list of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hool them up - links-Connection diagrams - link if needed-Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designsSoftware-burning bootloader - link-Core Tools - link-MIOS Studio and Additional tools - link.-The app and modification instructionsUsage manual linkThe template can can reside in the wiki, for people to utilise on new projects--------------that should get everyone off the ground.App development is a-whole-nother story.I don't think the blurred line can be completly removed - but can be made much more in focus.Perhaps there could be 2 main sections.Constructing and Custom App Dev.App dev section:Getting Started-burning bootloader - link-Core Tools - link-MIOS Studio and Additional tools - link.Basic App Dev-PIC types/details + pros and cons - link-Using the mios programming platform - link-Coding in C/asm - link to links-mios functions - link-Common errors/warnings/messages, what they mean and how to fix - linkAdvanced App Dev-using module code - eg. IIC, sdcard etc. - link-Custom Linkers - link-?more thats way beyond my skill level :DWikify Instructions-Link to 'how do I build a ...' template-etc--------------yep.... big...... Quote Link to comment Share on other sites More sharing options...
Durisian Posted October 16, 2008 Author Report Share Posted October 16, 2008 How to build a ... module templateGetting Started-Where to buy PCB's - link-How to etch - link-Where to buy parts - link-Tools Required - link-Soldering - link-Pin out list-.brd file-SchematicBuilding it-List of parts-Building instructions -link out to terminating cables, etc-Special Instructions links - (like smd soldering)-Testing-Common issues Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 16, 2008 Report Share Posted October 16, 2008 Damn, durisian, I thought I typed a lot! :DI like the idea of using templates like that to get some structure. I think the only section missing there, is the "How to build a [mbsid,mbfm,mblc,mbseq,etc]" , which allows a start-to-finish document. I guess it would go after the 'skills/equipment req'd' section, and each one would be a similar set of headings to the generalised 'hardware' section.Thanks for your effort man! Quote Link to comment Share on other sites More sharing options...
Twin-X Posted October 16, 2008 Report Share Posted October 16, 2008 Stop!!!Please do not do anything before i update the wiki software. I tell my self every day that i will update it but i constantly have excusses for not doing it.Currently we are lucky it still works with this version of smf.However the wiki is outdated and really needs a new version (also better for the plugins)Keep on dicussing on how it will look etc but do not take actions like this (it's a huge transformation) yet until i am done.I will have a look into it in the upcomming week for the upgrade. And i am pretty sure i end up by putting back a backup. :( Quote Link to comment Share on other sites More sharing options...
Durisian Posted October 16, 2008 Author Report Share Posted October 16, 2008 Thanks Twin.... oooo, upgrades.I tell myself everyday that when I get up, i'm going to run round the block a few times, do some sit ups and then some weights... it never happens ;DI think there will be some time before anything drastic happensI think the only section missing there, is the "How to build a [mbsid,mbfm,mblc,mbseq,etc]" I think you've missed a point - The template would be the guidline for all those.So there would be 'how to build a [mbdm, mblc, etc]' sections that are updated to follow the template. The concept being all project docos will follow the same format.A generic guide becomes almost irrelevant. However a basic run down of links at the top level would be handy for quick reference. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 16, 2008 Report Share Posted October 16, 2008 I think you've missed a point You're right I totally did. I'm with you now.Stop!!!>Insert screeching brakes noise here< ;DThanks Twinny. Hope it doesn't end up with a restore! Quote Link to comment Share on other sites More sharing options...
Twin-X Posted October 21, 2008 Report Share Posted October 21, 2008 The upgrade actually worked.However the boxes are still messed up.You can however recuest new plugins yay!!So happy documenting, now we are up to date!!---edit alot of spelling mistakes :( Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 22, 2008 Report Share Posted October 22, 2008 Yay! That was fast! thanks Twinny!Don't worry about the boxes, they never did work right :( Maybe a newer version might sort it out, we'll see... Durisian and I will look at the current crop of plugins.Durisian are you still in? Quote Link to comment Share on other sites More sharing options...
Durisian Posted October 22, 2008 Author Report Share Posted October 22, 2008 sure am!I've been working on a overall layout using a spreadsheet. The hardest part I'm finding is a way to keep it simple - but still keep the more advanced (and idea) documentation easy to find. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 23, 2008 Report Share Posted October 23, 2008 Chatroom? It's good for this kind of thing! Quote Link to comment Share on other sites More sharing options...
Durisian Posted October 23, 2008 Author Report Share Posted October 23, 2008 hey, yeah... the chatlet me find another can first ;DLayout StrucureStill a ton of stuff missing, but my brain hurts Quote Link to comment Share on other sites More sharing options...
Twin-X Posted October 23, 2008 Report Share Posted October 23, 2008 Oh yeah i like it. Specially the TOC is doing good for a quick find.However i preffer a chapter on it's own page. Now it is an incredible long list. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 23, 2008 Report Share Posted October 23, 2008 Rock'n :)Doing this groundwork is such a good idea man! It's just a short cut'n'paste operation after this (well...when you compare it to the alternatives heh)Volunteers get a lollipop! Quote Link to comment Share on other sites More sharing options...
buhler Posted November 5, 2008 Report Share Posted November 5, 2008 i'm really into this! i'm going to watch it closely. i need LOTS of hand holding so this is a great thing for me and my new project! :) (i really wanted ;D) Quote Link to comment Share on other sites More sharing options...
jimhenry Posted November 6, 2008 Report Share Posted November 6, 2008 The Miditzer community is working on a document that takes you through MIDIfying an organ console using the MIDIO128 project. So far, for the hardware part they are using my Building a Core and Wiring an LCD documents. There is a new Loading and Configuring MIDIO128 section that they've added. You can see what they have come up with here:http://www.jbwebserver.net/mforum/uploads/20081102_011310_Midio_Mysteries.pdfhttp://www.jbwebserver.net/mforum/uploads/20081102_011349_Midio_Mysteries.pdfThis kind of stuff should become part of the new and improved Wiki so let us know what we can do to help this effort. Quote Link to comment Share on other sites More sharing options...
Durisian Posted November 9, 2008 Author Report Share Posted November 9, 2008 That stuff is awesome Jim!I'm flat out till Jan so won't be doing much work on this till then.A large chunk of 'laying out' has been done - and just needs hands to copy/compile info in to the right places.Anyone/Everyone is welcome to just jump in! Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 10, 2008 Report Share Posted November 10, 2008 just needs hands to copy/compile info in to the right places.Anyone/Everyone is welcome to just jump in!OK good, I thought we were at that stage. We are "Go" for the wiki rejig. I'm a bit distracted at the moment but I'll do some bits and pieces soon.Jim Your doco is always first rate. I'll either convert those to wiki format or upload the PDFs. (Twin-X we still gotta fix that :( ) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 20, 2008 Report Share Posted November 20, 2008 I'm kicking this into place now.... The templates were a bit of a mishmash, there was a few circular links and misnamed pages, I've sorted it all out now... I think... It was really confusing...Here's the template:http://www.midibox.org/dokuwiki/doku.php?id=new_wiki_layoutIn the template, the links to pages at the root level all have this "new_wiki_layout" namespace as a prefix. When you create the new page, just remove it.The rest of the pages in the template lack the namespace, so the links are already as they should be.Go nuts!Edit: Example is the wikify pageTemplate:http://www.midibox.org/dokuwiki/doku.php?id=new_wiki_layout:wikifyEdited only to note that it has been overhauled, and linking to the overhauled page:http://www.midibox.org/dokuwiki/doku.php?id=wikify Quote Link to comment Share on other sites More sharing options...
