FJMSoft Posted October 28, 2008 Report Posted October 28, 2008 Hello there, I want to build a midibox64, I'm a bit lost, what should I program first in the PIC18F4620? Where to get?Please, step by step if you can.Thanks.
nILS Posted October 28, 2008 Report Posted October 28, 2008 1st: Burn bootloader.Where to get it: ucapps.de -> MIOS -> Download2nd: Upload MIOSWhere to get it: ucapps.de -> MIOS -> Download3rd: Upload mb64 appWhere to get it: ucapps.de -> MIOS -> Download;D
FJMSoft Posted October 28, 2008 Author Report Posted October 28, 2008 its this???1st. mios_update_v1_9f.zip ==> file: mios_update_v1_9f\pic18f4620\burner\bootloader_v1_2b_pic18f4620.hex2nd. mios_update_v1_9f.zip ==> file: mios_update_v1_9f\pic18f4620\mios_v1_9f_pic18f4620.hex3rd. midibox64_v2_4b.zip ==> midibox64_v2_4b\setup_midibox64.hex (Via midi)its right?
FJMSoft Posted October 28, 2008 Author Report Posted October 28, 2008 oh well, this means it is right, I will try... Thanks ;)
FJMSoft Posted November 4, 2008 Author Report Posted November 4, 2008 Hi again... I've mounted JDM programmer, and tried to burn the PIC with winpic800... just selected JDM on COM1, it detected the PIC18F4620, so I loaded the HEX file, and clicked program all... it taken less than 5 seconds, said it is ok... so I clicked verify... took very longer, said ok too (made this many times)... this means it is burn properly?I became a bit confused with a page config... with many strange configurations, for me looks like Microcontroller configuration... I need to change something? I leave untouched...How do I program the rest which is by midi... with mios studio?If I want to do this in a protoboard, what is needed?Thanks!
nILS Posted November 5, 2008 Report Posted November 5, 2008 The easy route would be to stick the PIC in a core. If you wanna do it on protoboard you'll need the PIC, the power parts then MIDI In and the MIDI out parts.
FJMSoft Posted November 5, 2008 Author Report Posted November 5, 2008 Thanks nILS!About the burning, you think it gone ok? How can I test if its ok?
nILS Posted November 5, 2008 Report Posted November 5, 2008 If verifying succeeds it's very unlikely that it did not work ;-)
FJMSoft Posted November 5, 2008 Author Report Posted November 5, 2008 What happens if I upload more than one time the mios update or the midibox application via midi?
nILS Posted November 5, 2008 Report Posted November 5, 2008 Nothing. If you re-upload MIOS you'll delete the application you may have uploaded earlier, but other than that, nothing will happen.
FJMSoft Posted November 6, 2008 Author Report Posted November 6, 2008 Thanks a lot nILS... Its working!!!
