bosone Posted November 10, 2008 Report Share Posted November 10, 2008 is it possible to add now chords to the appropriate table??i tried to edit the seq_chord.inc file by adding some new chords:SEQ_CHORD_TABLE ;; 1 2 3 4 <----> (6 chars!) CHORD_ENTRY 0, 4, 7, -1, "Maj.I " CHORD_ENTRY 4, 7, 12, -1, "Maj.II" CHORD_ENTRY 7, 12, 16, -1, "MajIII" CHORD_ENTRY 0, -1, -1, -1, "Root " CHORD_ENTRY 4, -1, -1, -1, "3rd " CHORD_ENTRY 7, -1, -1, -1, "5th " CHORD_ENTRY 0, 4, -1, -1, "R.+3rd" CHORD_ENTRY 0, 7, -1, -1, "R.+5th" CHORD_ENTRY 0, 8, -1, -1, "3rd+R." CHORD_ENTRY 0, 5, -1, -1, "5th+R." CHORD_ENTRY 0, 4, 7, 9, "Maj.6 " CHORD_ENTRY 0, 4, 7, 11, "Maj.7 " CHORD_ENTRY 0, 4, 7, 12, "Maj.8 " CHORD_ENTRY 0, 4, 7, 14, "Maj.9 " CHORD_ENTRY 0, 4, 7, 16, "Maj.10" CHORD_ENTRY 0, 7, 12, 17, "Maj.11" CHORD_ENTRY 0, 7, 12, 19, "Maj.12" CHORD_ENTRY 0, 7, 12, 21, "Maj.13" CHORD_ENTRY 0, 2, 7, -1, "Sus.2 " CHORD_ENTRY 0, 5, 7, -1, "Sus.4 " CHORD_ENTRY 0, 4, 8, -1, "Maj.5+" CHORD_ENTRY 0, 4, 6, -1, "Maj.5-" CHORD_ENTRY 0, 4, 6, 10, "7b 5- " CHORD_ENTRY 0, 4, 7, 10, "Dom.7 "but the last chord i get is "Maj.11", so i suppose that there is a variable, somewhere, that defines the length of this table.can the table length be changed?thanks! Quote Link to comment Share on other sites More sharing options...
moroe Posted November 12, 2008 Report Share Posted November 12, 2008 maybe another entry in the seq V4 wihlist ?greetsmoroe Quote Link to comment Share on other sites More sharing options...
bosone Posted November 12, 2008 Author Report Share Posted November 12, 2008 if it applies for seq4, it could be worthwile to consider also the various inversion of the chords...ex: C E G B (maj7) can also be played: EGBC, GBCE, BCEG ;) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 13, 2008 Report Share Posted November 13, 2008 i suppose that there is a variable, somewhere, that defines the length of this table.It's built in....;; --------------------------------------------------------------------------;; This function prints the chord name + octave;; IN: WREG[3:0]: chord number;; WREG[6:4]: octave transpose -4..+3;; OUT: 8 characters;; USES: BSR, TBLPTR[LH], TABLAT, PROD[LH];; --------------------------------------------------------------------------Note: only 4 bits for the chord number.Course, you can always replace them with your own selection.... Quote Link to comment Share on other sites More sharing options...
TK. Posted November 15, 2008 Report Share Posted November 15, 2008 Yes, as StrydOne already mentioned: chords are selected with a 4bit value, accordingly only 16 chords can be predefined.As a workaround, you could use chord mode #1 which allows you to take customized chords from a second track. Up to 32 chords can be stored this way, you can use the step record function for manual entry, or edit the notes directly with the encoders.Unfortunately this methods limits the number of notes to 3 (corresponds with the number of parameter layers). In MBSQ V4, there will be a 4th parameter layer to overcome this (and other) limitations.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
