freddy Posted January 7, 2009 Posted January 7, 2009 Folks,I have two different C64 PSUs, one is from C64 (whose box is hosting 4x v1 SIDs) and a C64-II PSU. When powering either 4x v1 SIDs or 4x core v2 MB6581 with the old C64 PSU, everything works as a charm.When using C64-II PSU, for the 4x v1 SIDs I get _lots_ of humming in the resulting mixed channel (but the SID modules do work, actually), v2 MB6582 even doesn't power up properly - the 4x20 backlit LCD gets lit, first and third line are blacked out and I cannot get any further, no CS LEDs lit, but the humming can be heard.When I measure the voltages, +12V for SIDs is okay in both cases, but instead of 4.99V I'm getting with old C64 PSU I only get +4.45V for PICs, 5V fan, HC595, LC256, etc. When I measure unloaded PSUs, for the C64 (old one) I'm getting +5.22V, for the newer C64-II barely +4.03V.I suppose this humming is caused by low voltage, as is the "unability to boot" (because of higher load of v2 MB6581), but can someone audio-skilled confirm this before I start opening the C64 PSU? Any similiar experience (i.e. to what to look at inside the C64 PSU)?Thanks.
Natsirt Posted January 7, 2009 Posted January 7, 2009 i.e. to what to look at inside the C64 PSU)I would hazard that you'd probably be disappointed by what you found, were you to open one.AFIK, most of these supplies aren't really serviceable; All of the electronics are housed inthis icky resinous goo, and I've found that the plastic case likes to eat fingers for breakfast...
Goblinz Posted January 7, 2009 Posted January 7, 2009 I would hazard that you'd probably be disappointed by what you found, were you to open one.AFIK, most of these supplies aren't really serviceable; All of the electronics are housed inthis icky resinous goo, and I've found that the plastic case likes to eat fingers for breakfast... I was very pleased with what I found in my broken C64 CPU ... A burnt out fuse :D
