Info for pins and cables
demym
Hi to all,
does anyone knows where is it possible to buy those pin to pin cables that are usually found into pc motherboards boxes (and that are typically used to connect internal USB or internal CDROM).. I've searched all over, but seem not to find connectors to build such type of cables.. I think they are very useful to make flying connections pin to pin (to try some circuit).. Are them perhaps called Molex mini-fit ?
I already have strips of female pin connectors, but i would preferr something that doesn't force me to solder only to try a connection.
I had some of those cables, and used them and enjoyed, but i have no more to use now..
Thanks very much in advance
http://fr.mouser.com/Search/ProductDetail.aspx?R=50-57-9005virtualkey53810000virtualkey538-50-57-9005
http://fr.mouser.com/Search/ProductDetail.aspx?R=16-02-0097virtualkey53810000virtualkey538-16-02-0097
you also need the right tool to do the bending. Small and solid pliers works well. Or you could use same crimping tool as Smash. Get some patience as well, this can get really boring. Once done those cables a really helpful.
