Experimental controllers sensors ribbons et cetera
clem!
Hi all!
What about starting little experiments with alternate controllers and sensors.
Maybe at first we can sample the resistance of different video tapes (I´ve found some old panasonic ones), we can also measure adhesive metal tapes or other materials like different graphit-finishs and put the´samples together into a database.
Don´t know if this is the right place to do that - any suggestions.
Hope there´s s.o. else.
i've tested some antistatic nylon bag in which ICs are packed for use as a ribbon controller. i haven't completed this project until now because my main circuits didn't work (psu?).
it has the required resistance of 100 kohms when cut to a band of about 20cm / 1cm. these were recommended for a diy belt controller project, the builder did it with adhesive tape and graphite powder and a brass strip, i intended to use this nylon with a violin string.
the website i found the original circuit with the adhesive tape has some very interesting projects with vacuum tubes:
http://www.electronicpeasant.com/
Hahah that was my first thought and I didn't post it... my stupid memory :) ACSensorizer is midibox stuff and you can find goodies on our wiki/forums too...
AudioCommander has done great work with this, it's a must-see for alternative controls.
First samples of video-tapes:
Manufacturer;      Format;        Type;             Resistance per 10 cm;
Panasonic;           MII;              AU-M60L;       11 M;
Panasonic;           S-VHS;          XD;               4,3 M;
Sony;                 Betacam SP;   BCT-30MA      4,6 M;
Panasonic;           S-VHS;          SE-30;          7,8 M;
Kodak;                VHS;            HS-E240;        2,3 M;
TDK;                   VHS;             E-240TV;       -;
TDK;                   VHS;             EHG;             -;
Akai;                   VHS;             HQ;              -;
Agfa;                  VHS;             S-HGX;          -;
Hi all,
found another one - this is as somewhere else told a scotch consumer one.
Scotch;              VHS;            EXG+;             37 K;
looks much better!
clem!
Resistance per 10 cm          37 K
looks much better!
hi clem!
which resistor value/length are you looking for, what would be the best?
do you prefer video tape (bec. availability)?
perhaps i could measure some old multitrack and stereo recording tape too.
but i actually think those tapes would easily wear down after short use because you'd always have to press a metallic surface on a very thin layered film...
hi rosch,
first project is to build a controller with the full length of a keybord with 61 standard keys for my keyboardcontroller-midification-project. That means 10 k at ~86 cm.
But "I have a dream" for the next project - of building a continuus-polyphonic-velocity-sensitive-(midi)-controller (schoene Wortkreation) for small money like the continuum at haken audio which costs megas.
Maybe we can find s.t. like graphite-cotton ;) mmh.
So let´s test everything we can find and put the information together.
clem!
  • 4 weeks later...
hi and thx for the quick respond,
Yes I´ve seen that, but it has a to low resistance.
For our aim, building wire-controlers, we need a diameter of 0,01 mm with a resistance of 11580 Ohm. I think with this wire we can also build shorter controlers of 30 or 15 cm - hope they won´t get to hot  8)
Regards
Toaster wire?
Good idea!
... there must be ... somewhere ... a broken toaster
That's *very* thin... are you sure?
of course it´s thin, but if we fix it on a plastic strip it must work - I hope so - if not we need a wire  with a bigger diameter made of other material.
clem!
  • 1 year later...
