noofny Posted April 4, 2009 Posted April 4, 2009 I'm almost done making my midibox and getting the code working...and wondering if it's worthwhile adding my code to the source repo? Some of the code is very much customized to my needs but there may be some things others can benefit from. Am happy to share it anyway. I've found some posts about some developers lounge - do I need access to that or can I use svn to checkin?
nILS Posted April 6, 2009 Posted April 6, 2009 Yes you do. Write a PM to TK and ask him nicely for access.
TK. Posted April 6, 2009 Posted April 6, 2009 You've now access to the programmers section of this forum, where you will find the informations to get SVN access.Best Regards, Thorsten.
noofny Posted April 8, 2009 Author Posted April 8, 2009 I followed the steps to setup Putty and generate the key etc here;http://www.midibox.org/forum/index.php/topic,10691.0.htmlhttp://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_svn#puttybut when I connect using Putty I get;Using username "svn".Server refused our keysvn@svnmios.midibox.org's password: I stepped through the process again very carefully...am I missing something?Read access is working fine...just the write access using ssh aint.cheers
TK. Posted April 8, 2009 Posted April 8, 2009 You have to post your public DSA key here:http://www.midibox.org/forum/index.php/topic,10644.0.htmlBest Regards, Thorsten.
