I'm almost done making my midibox and getting the code working...and wondering if it's worthwhile adding my code to the source repo? Some of the code is very much customized to my needs but there may be some things others can benefit from. Am happy to share it anyway.
I've found some posts about some developers lounge - do I need access to that or can I use svn to checkin?
You've now access to the programmers section of this forum, where you will find the informations to get SVN access.
I followed the steps to setup Putty and generate the key etc here;
http://www.midibox.org/forum/index.php/topic,10691.0.html
http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_svn#putty
but when I connect using Putty I get;
Using username "svn".
Server refused our key
svn@svnmios.midibox.org's password:
I stepped through the process again very carefully...am I missing something?
Read access is working fine...just the write access using ssh aint.
cheers
