Austin73 Posted April 27, 2009 Posted April 27, 2009 Hi been trying to sort out a joystick for my planned Midibox 64 did the usual search ;) and found that using a poc joystick might be cheap and good fun. I opened up a Logitech Extreme 3D and did tests on the pots and they come back at between 20k and 100k - Is the Midi box able to scale the pot response to what it needs or do all pots need to be 10k?I hope this makes sense.CheersAus
nILS Posted April 27, 2009 Posted April 27, 2009 20k will work nicely, I don' know about the 100k though - just go ahead and try it ;)
thepcman Posted August 15, 2009 Posted August 15, 2009 100k is a comparable impedance to PIC analog input. If you MUST use it, adding buffer circuit will solve the problem.
