MIDIBOX 64E trouble with pots
Hello Everyone !
I finished my second midibox today - MIDIBOX64e - my first is MIDIBOX64.
I have :
4 encoders
16 buttons
16 faders
I noticed that fadres still sends data if  they are on break down - just when all be upraised send data is stopped
this normal and how to do away this ??
Cheers
Daniel
Hi Daniel,
That suggests that either:
Your faders are wired incorrectly - if that is the case, you could cause a short and blow up the parts, so I would turn it off immediately and triple-check it...
or maybe, your PSU is extremely noisey...
I change my PSU and trouble is the same :( , and faders are wired correctly ... when I change software from MB64E to MB64 everything is ok. Maybe  my config file is wrong ??
I could be wrong, but in setup file for MB64E for faders you only need define quantity = 16 and enabled mux = 1 :
#define DEFAULT_NUMBER_AIN          16
#define DEFAULT_ENABLE_AIN_MUX    1
Regards, Janis
This could as stryd_one said be caused by noise on the Gnd-Vd rail. What kind of PSU are you using? Also you can try adding some caps between Vd and Gnd near the faders and see if that helps.
  • 3 months later...
