unrise_lyrical Posted June 2, 2009 Posted June 2, 2009 Hey guys,I am building a strobe kit I bought off ebay to get my soldering skills up to scratch for building a mbSID, and I am pretty much finished. I am about to solder in the 3 ICs, but the instructions are lacking (to say the least) and I am a tad worried about their orientation. The bigger one is easily oriented, as it has a notch at one end which corresponds with the image provided. The other 2 however (one is a 555 timer, the other I am not sure) dont have notches, but dimples at one end. The image shows them all with the notch at one end however. I just wanted to check, are these the same thing? as in, even though these have dimples, not notches, if the dimple is at the same end as the notch in the drawing, are they oriented correctly?
lylehaze Posted June 2, 2009 Posted June 2, 2009 if the dimple is at the same end as the notch in the drawing, are they oriented correctly? Yes.The dimple is pin 1the notch is at the same end as Pin 1
unrise_lyrical Posted June 2, 2009 Author Posted June 2, 2009 awesome :D thats for the speedy reply mate! Soldered them in...my first time doing ICs....hope I didnt cook them! :-[
strophlex Posted June 2, 2009 Posted June 2, 2009 In the future, use IC-sockets. Then you won't risk cooking the ICs and you can easily flip or replace them. Hope the strobe works :)
unrise_lyrical Posted June 2, 2009 Author Posted June 2, 2009 yea, it was annoying none came with the kit. If they are cooked, I will get some when I replace the chips (dont think they will be too hard to source...one of them is a 555 timer, that much im sure of). Was just too lazy/broke to get some this time :)
