Steven_C Posted July 21, 2003 Posted July 21, 2003 from main.asm;; used by lc_ledrings.incLEDRINGS_SR_CATHODES EQU 8 ; shift register with cathodes of the 8 LED ringsLEDRINGS_SR_ANODES_1 EQU 10 ; first shift register with anodes of the 8 LED ringsLEDRINGS_SR_ANODES_2 EQU 11 ; second shift register with anodes of the 8 LED ringsI assume I won't have to change these numbers?from lc_io_tableLC_IO_TABLE_LAYER0 ;; 1st shift register ;; button LED db ID_REC_RDY_CHN1, ID_REC_RDY_CHN1 db ID_REC_RDY_CHN2, ID_REC_RDY_CHN2 db ID_REC_RDY_CHN3, ID_REC_RDY_CHN3 db ID_REC_RDY_CHN4, ID_REC_RDY_CHN4 db ID_REC_RDY_CHN5, ID_REC_RDY_CHN5 db ID_REC_RDY_CHN6, ID_REC_RDY_CHN6 db ID_REC_RDY_CHN7, ID_REC_RDY_CHN7 db ID_REC_RDY_CHN8, ID_REC_RDY_CHN8 ;; 2nd shift register ;; button LED db ID_SOLO_CHN1, ID_SOLO_CHN1 db ID_SOLO_CHN2, ID_SOLO_CHN2 db ID_SOLO_CHN3, ID_SOLO_CHN3 db ID_SOLO_CHN4, ID_SOLO_CHN4 db ID_SOLO_CHN5, ID_SOLO_CHN5 db ID_SOLO_CHN6, ID_SOLO_CHN6 db ID_SOLO_CHN7, ID_SOLO_CHN7 db ID_SOLO_CHN8, ID_SOLO_CHN8 ;; 3rd shift register ;; button LED db ID_MUTE_CHN1, ID_MUTE_CHN1 db ID_MUTE_CHN2, ID_MUTE_CHN2 db ID_MUTE_CHN3, ID_MUTE_CHN3 db ID_MUTE_CHN4, ID_MUTE_CHN4 db ID_MUTE_CHN5, ID_MUTE_CHN5 db ID_MUTE_CHN6, ID_MUTE_CHN6 db ID_MUTE_CHN7, ID_MUTE_CHN7 db ID_MUTE_CHN8, ID_MUTE_CHN8 ;; 4th shift register ;; button LED db ID_SELECT_CHN1, ID_SELECT_CHN1 db ID_SELECT_CHN2, ID_SELECT_CHN2 db ID_SELECT_CHN3, ID_SELECT_CHN3 db ID_SELECT_CHN4, ID_SELECT_CHN4 db ID_SELECT_CHN5, ID_SELECT_CHN5 db ID_SELECT_CHN6, ID_SELECT_CHN6 db ID_SELECT_CHN7, ID_SELECT_CHN7 db ID_SELECT_CHN8, ID_SELECT_CHN8 ;; 5th shift register ;; button LED db ID_ASSIGN_TRACK, ID_ASSIGN_TRACK db ID_ASSIGN_SEND, ID_ASSIGN_SEND db ID_ASSIGN_PAN_SURROUND, ID_ASSIGN_PAN_SURROUND db ID_ASSIGN_PLUG_IN, ID_ASSIGN_PLUG_IN db ID_ASSIGN_EQ, ID_ASSIGN_EQ db ID_ASSIGN_INSTRUMENT, ID_ASSIGN_INSTRUMENT db ID_BANK_LEFT, ID_IGNORE ; (no LED supported by host) db ID_BANK_RIGHT, ID_IGNORE ; (no LED supported by host) ;; 6th shift register ;; button LED db ID_BANK_CHANNEL_LEFT, ID_IGNORE ; (no LED supported by host) db ID_BANK_CHANNEL_RIGHT, ID_IGNORE ; (no LED supported by host) db ID_FLIP, ID_FLIP db ID_GLOBAL_VIEW, ID_GLOBAL_VIEW db ID_SHIFT, ID_IGNORE ; (no LED supported by host) db ID_OPTION, ID_IGNORE ; (no LED supported by host) db ID_CONTROL, ID_IGNORE ; (no LED supported by host) db ID_CMD_ALT, ID_IGNORE ; (no LED supported by host) ;; 7th shift register ;; button LED db ID_MARKER, ID_MARKER db ID_NUDGE, ID_NUDGE db ID_CYCLE, ID_CYCLE db ID_DROP, ID_DROP db ID_REPLACE, ID_REPLACE db ID_CLICK, ID_CLICK db ID_REWIND, ID_REWIND db ID_FAST_FWD, ID_FAST_FWD ;; 8th shift register ;; button LED db ID_STOP, ID_STOP db ID_PLAY, ID_PLAY db ID_RECORD, ID_RECORD db ID_CURSOR_UP, ID_IGNORE ; (no LED supported by host) db ID_CURSOR_LEFT, ID_IGNORE ; (no LED supported by host) db ID_ZOOM, ID_ZOOM db ID_CURSOR_RIGHT, ID_IGNORE ; (no LED supported by host) db ID_CURSOR_DOWN, ID_IGNORE ; (no LED supported by host) ;; 9th shift register ;; button LED db ID_VPOT_SELECT_CHN1, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN2, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN3, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN4, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN5, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN6, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN7, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN8, ID_IGNORE ; (no LED supported by host) ;; 10th shift register ;; button LED db ID_GLOBAL_TRACKS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_INPUTS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUDIO_TRCK, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUDIO_INSTR, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUX, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_BUSSES, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_OUTPUTS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_USER, ID_IGNORE ; (no LED supported by host) ;; 11th shift register ;; button LED db ID_AUTOM_READ_OFF, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_WRITE, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_TRIM, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_TOUCH, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_LATCH, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_UTIL_CANCEL, ID_IGNORE ; (no LED supported by host) db ID_UTIL_ENTER, ID_IGNORE ; (no LED supported by host) db ID_MBLC_HOLD_LAYER, ID_IGNORE ; (MIDIbox LC specific: switch to other layer when button (de)pressed) ;; 12th shift register ;; button LED db ID_F1, ID_IGNORE ; (no LED supported by host) db ID_F2, ID_IGNORE ; (no LED supported by host) db ID_F3, ID_IGNORE ; (no LED supported by host) db ID_F4, ID_IGNORE ; (no LED supported by host) db ID_F5, ID_IGNORE ; (no LED supported by host) db ID_F6, ID_IGNORE ; (no LED supported by host) db ID_F7, ID_IGNORE ; (no LED supported by host) db ID_F8, ID_IGNORE ; (no LED supported by host) ;; 13th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) ;; 14th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) ;; 15th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) ;; 16th shift register ;; button LED db ID_FADER_TOUCH_CHN1, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN2, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN3, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN4, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN5, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN6, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN7, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN8, ID_IGNORE ; (no LED supported by host)can someone tell me what I have to change here to get the LEDrings working?from lc_io_tableLC_IO_TABLE_LAYER0 ;; 1st shift register ;; button LED db ID_MBLC_SWITCH_LEDMETER1 , ID_REC_RDY_CHN1 db ID_REC_RDY_CHN2, ID_REC_RDY_CHN2 db ID_REC_RDY_CHN3, ID_REC_RDY_CHN3 db ID_REC_RDY_CHN4, ID_REC_RDY_CHN4 db ID_REC_RDY_CHN5, ID_REC_RDY_CHN5 db ID_REC_RDY_CHN6, ID_REC_RDY_CHN6 db ID_REC_RDY_CHN7, ID_REC_RDY_CHN7 db ID_REC_RDY_CHN8, ID_REC_RDY_CHN8if I modified it like this, would that mean that pin one on SR one would switch the LCD meter into a horizontal LEDring?sorry to ask so many questions at once, thanks, from Steve
TK. Posted July 22, 2003 Posted July 22, 2003 Hi Steve,yes, the LEDRINGS_SR_* settings are used to define the position of the shift registers which are connected to the LED rings. In difference to lc_io_tables.inc the shift registers are counted from zero here!See also this schematic:http://www.ucapps.de/mbhp/mbhp_doutx4_lc_ledrings.pdfit means that LEDRINGS_SR_CATHODES are located at the 9th SR, therefore number 8, and the anodes are located at SR 10 and 11.SR 9 is reserved for seperate meters, but if you don't plan to add them, you could either change the default settings or use this spare shift register for additional LED functions.ID_MBLC_SWITCH_LEDMETER1 switches to the meter mode, but doesn't switch back. So you have to assign at least one additional button to ID_MBLC_SWITCH_LEDMETER0or use a single button with ID_MBLC_TOGGLE_LEDMETER for a toggle function, resp. ID_MBLC_HOLD_LEDMETER for a shift function FAQMARKERBest Regards, Thorsten.
d2k Posted July 23, 2003 Posted July 23, 2003 T...Just seen this new pdf and i'm a lil concered, i thought your able to place the meterbar LEDs anywhere on the dout chain - not just after the vpot rings...My design has the meterleds rings on a sep core, which is also used for the forthcoming MTC digits aswell as a single pot for the maser fader...is this still okay?, as i thought it was from a q i posted a while bak...have i got my wires mixed up - so to speak...or is just an example setup uve posted?Best...Dan
TK. Posted July 23, 2003 Posted July 23, 2003 Yes, you can place the meter LEDs anywhere - damned! thats the problem when the application allows too much options - how to answer a simple question with one sentence when so much variations are possible? :-( You see: under these circumstances the LC documentation will never be finished... ;-)Best Regards, thorsten.
Steven_C Posted July 23, 2003 Author Posted July 23, 2003 Thanks Thorsten!I'm just wondering, why my encoders work properly, when in the 13th and 14th SR, it says "db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here)"and I never changed this before I built the main.HEX file?in the standard lc application, will the ledrings work straight away without configuring, if I just connect them to the right shift registers?if I connect the ledrings like in the pdf, will they work straight away, or will I have to assign the SR pins in the lc_IO_table? I am using mios 1.2, as the faders go erratic when I try 1.3 (they kind of don't stop at the target position, they keep going!Yes, you can place the meter LEDs anywhere - damned![Your design is like Logic audio... too many options for beginners, but everything possible that an expert needs! When I get time, I will make a step by step webpage on how to build the standard LC, with upgrade options and things... for beginners, maybe with a modular frontpanel or something! Unless someone beats me to it!Thanks Thorsten!If someone else can help, could they please save Thorsten from all the typing? ;)
Steven_C Posted July 25, 2003 Author Posted July 25, 2003 don't worry about answering this, (unless it is for others) cos I probably won't fit Ledrings :P
TK. Posted July 26, 2003 Posted July 26, 2003 Hi Steve,When I get time, I will make a step by step webpage on how to build the standard LC, with upgrade options and things... for beginners, maybe with a modular frontpanel or something! Unless someone beats me to it! this would be really helpfull! :) Some infos to LEDrings and encoder settings:buttons are "shadowed" by the encoder pins. Means: once you've assigned two pins to an encoder in mios_tables.inc, these pins will not trigger a button function anymore, therefore the appr. button entries in lc_io_tables.inc will never be processed.digital output pins are "shadowed" by LEDring assignments. Means: the shift registers for anodes/cathodes which are assigned to the LEDring handler cannot be used for common LED functions defined in lc_io_tables.inc, since the handler overwrite the values every milisecondBest Regards, Thorsten.FAQMARKER
Steven_C Posted August 13, 2003 Author Posted August 13, 2003 ID_MBLC_SWITCH_LEDMETER1 switches to the meter mode, but doesn't switch back. So you have to assign at least one additional button to ID_MBLC_SWITCH_LEDMETER0 or use a single button with ID_MBLC_TOGGLE_LEDMETER for a toggle function, resp. ID_MBLC_HOLD_LEDMETER for a shift function can these functions be used to switch the LCD meters into ledring bars on 40x2? (sick of soldering!)
