Steven_C Posted July 21, 2003 Report Posted July 21, 2003 from main.asm;; used by lc_ledrings.incLEDRINGS_SR_CATHODES EQU 8 ; shift register with cathodes of the 8 LED ringsLEDRINGS_SR_ANODES_1 EQU 10 ; first shift register with anodes of the 8 LED ringsLEDRINGS_SR_ANODES_2 EQU 11 ; second shift register with anodes of the 8 LED ringsI assume I won't have to change these numbers?from lc_io_tableLC_IO_TABLE_LAYER0 ;; 1st shift register ;; button LED db ID_REC_RDY_CHN1, ID_REC_RDY_CHN1 db ID_REC_RDY_CHN2, ID_REC_RDY_CHN2 db ID_REC_RDY_CHN3, ID_REC_RDY_CHN3 db ID_REC_RDY_CHN4, ID_REC_RDY_CHN4 db ID_REC_RDY_CHN5, ID_REC_RDY_CHN5 db ID_REC_RDY_CHN6, ID_REC_RDY_CHN6 db ID_REC_RDY_CHN7, ID_REC_RDY_CHN7 db ID_REC_RDY_CHN8, ID_REC_RDY_CHN8 ;; 2nd shift register ;; button LED db ID_SOLO_CHN1, ID_SOLO_CHN1 db ID_SOLO_CHN2, ID_SOLO_CHN2 db ID_SOLO_CHN3, ID_SOLO_CHN3 db ID_SOLO_CHN4, ID_SOLO_CHN4 db ID_SOLO_CHN5, ID_SOLO_CHN5 db ID_SOLO_CHN6, ID_SOLO_CHN6 db ID_SOLO_CHN7, ID_SOLO_CHN7 db ID_SOLO_CHN8, ID_SOLO_CHN8 ;; 3rd shift register ;; button LED db ID_MUTE_CHN1, ID_MUTE_CHN1 db ID_MUTE_CHN2, ID_MUTE_CHN2 db ID_MUTE_CHN3, ID_MUTE_CHN3 db ID_MUTE_CHN4, ID_MUTE_CHN4 db ID_MUTE_CHN5, ID_MUTE_CHN5 db ID_MUTE_CHN6, ID_MUTE_CHN6 db ID_MUTE_CHN7, ID_MUTE_CHN7 db ID_MUTE_CHN8, ID_MUTE_CHN8 ;; 4th shift register ;; button LED db ID_SELECT_CHN1, ID_SELECT_CHN1 db ID_SELECT_CHN2, ID_SELECT_CHN2 db ID_SELECT_CHN3, ID_SELECT_CHN3 db ID_SELECT_CHN4, ID_SELECT_CHN4 db ID_SELECT_CHN5, ID_SELECT_CHN5 db ID_SELECT_CHN6, ID_SELECT_CHN6 db ID_SELECT_CHN7, ID_SELECT_CHN7 db ID_SELECT_CHN8, ID_SELECT_CHN8 ;; 5th shift register ;; button LED db ID_ASSIGN_TRACK, ID_ASSIGN_TRACK db ID_ASSIGN_SEND, ID_ASSIGN_SEND db ID_ASSIGN_PAN_SURROUND, ID_ASSIGN_PAN_SURROUND db ID_ASSIGN_PLUG_IN, ID_ASSIGN_PLUG_IN db ID_ASSIGN_EQ, ID_ASSIGN_EQ db ID_ASSIGN_INSTRUMENT, ID_ASSIGN_INSTRUMENT db ID_BANK_LEFT, ID_IGNORE ; (no LED supported by host) db ID_BANK_RIGHT, ID_IGNORE ; (no LED supported by host) ;; 6th shift register ;; button LED db ID_BANK_CHANNEL_LEFT, ID_IGNORE ; (no LED supported by host) db ID_BANK_CHANNEL_RIGHT, ID_IGNORE ; (no LED supported by host) db ID_FLIP, ID_FLIP db ID_GLOBAL_VIEW, ID_GLOBAL_VIEW db ID_SHIFT, ID_IGNORE ; (no LED supported by host) db ID_OPTION, ID_IGNORE ; (no LED supported by host) db ID_CONTROL, ID_IGNORE ; (no LED supported by host) db ID_CMD_ALT, ID_IGNORE ; (no LED supported by host) ;; 7th shift register ;; button LED db ID_MARKER, ID_MARKER db ID_NUDGE, ID_NUDGE db ID_CYCLE, ID_CYCLE db ID_DROP, ID_DROP db ID_REPLACE, ID_REPLACE db ID_CLICK, ID_CLICK db ID_REWIND, ID_REWIND db ID_FAST_FWD, ID_FAST_FWD ;; 8th shift register ;; button LED db ID_STOP, ID_STOP db ID_PLAY, ID_PLAY db ID_RECORD, ID_RECORD db ID_CURSOR_UP, ID_IGNORE ; (no LED supported by host) db ID_CURSOR_LEFT, ID_IGNORE ; (no LED supported by host) db ID_ZOOM, ID_ZOOM db ID_CURSOR_RIGHT, ID_IGNORE ; (no LED supported by host) db ID_CURSOR_DOWN, ID_IGNORE ; (no LED supported by host) ;; 9th shift register ;; button LED db ID_VPOT_SELECT_CHN1, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN2, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN3, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN4, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN5, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN6, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN7, ID_IGNORE ; (no LED supported by host) db ID_VPOT_SELECT_CHN8, ID_IGNORE ; (no LED supported by host) ;; 10th shift register ;; button LED db ID_GLOBAL_TRACKS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_INPUTS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUDIO_TRCK, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUDIO_INSTR, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_AUX, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_BUSSES, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_OUTPUTS, ID_IGNORE ; (no LED supported by host) db ID_GLOBAL_USER, ID_IGNORE ; (no LED supported by host) ;; 11th shift register ;; button LED db ID_AUTOM_READ_OFF, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_WRITE, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_TRIM, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_TOUCH, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_AUTOM_LATCH, ID_IGNORE ; (in my setup no LEDs are connected here) db ID_UTIL_CANCEL, ID_IGNORE ; (no LED supported by host) db ID_UTIL_ENTER, ID_IGNORE ; (no LED supported by host) db ID_MBLC_HOLD_LAYER, ID_IGNORE ; (MIDIbox LC specific: switch to other layer when button (de)pressed) ;; 12th shift register ;; button LED db ID_F1, ID_IGNORE ; (no LED supported by host) db ID_F2, ID_IGNORE ; (no LED supported by host) db ID_F3, ID_IGNORE ; (no LED supported by host) db ID_F4, ID_IGNORE ; (no LED supported by host) db ID_F5, ID_IGNORE ; (no LED supported by host) db ID_F6, ID_IGNORE ; (no LED supported by host) db ID_F7, ID_IGNORE ; (no LED supported by host) db ID_F8, ID_IGNORE ; (no LED supported by host) ;; 13th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) ;; 14th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) ;; 15th shift register ;; button LED db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) db ID_IGNORE, ID_IGNORE ; (spare pin in my setup) ;; 16th shift register ;; button LED db ID_FADER_TOUCH_CHN1, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN2, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN3, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN4, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN5, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN6, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN7, ID_IGNORE ; (no LED supported by host) db ID_FADER_TOUCH_CHN8, ID_IGNORE ; (no LED supported by host)can someone tell me what I have to change here to get the LEDrings working?from lc_io_tableLC_IO_TABLE_LAYER0 ;; 1st shift register ;; button LED db ID_MBLC_SWITCH_LEDMETER1 , ID_REC_RDY_CHN1 db ID_REC_RDY_CHN2, ID_REC_RDY_CHN2 db ID_REC_RDY_CHN3, ID_REC_RDY_CHN3 db ID_REC_RDY_CHN4, ID_REC_RDY_CHN4 db ID_REC_RDY_CHN5, ID_REC_RDY_CHN5 db ID_REC_RDY_CHN6, ID_REC_RDY_CHN6 db ID_REC_RDY_CHN7, ID_REC_RDY_CHN7 db ID_REC_RDY_CHN8, ID_REC_RDY_CHN8if I modified it like this, would that mean that pin one on SR one would switch the LCD meter into a horizontal LEDring?sorry to ask so many questions at once, thanks, from Steve Quote
TK. Posted July 22, 2003 Report Posted July 22, 2003 Hi Steve,yes, the LEDRINGS_SR_* settings are used to define the position of the shift registers which are connected to the LED rings. In difference to lc_io_tables.inc the shift registers are counted from zero here!See also this schematic:http://www.ucapps.de/mbhp/mbhp_doutx4_lc_ledrings.pdfit means that LEDRINGS_SR_CATHODES are located at the 9th SR, therefore number 8, and the anodes are located at SR 10 and 11.SR 9 is reserved for seperate meters, but if you don't plan to add them, you could either change the default settings or use this spare shift register for additional LED functions.ID_MBLC_SWITCH_LEDMETER1 switches to the meter mode, but doesn't switch back. So you have to assign at least one additional button to ID_MBLC_SWITCH_LEDMETER0or use a single button with ID_MBLC_TOGGLE_LEDMETER for a toggle function, resp. ID_MBLC_HOLD_LEDMETER for a shift function FAQMARKERBest Regards, Thorsten. Quote
d2k Posted July 23, 2003 Report Posted July 23, 2003 T...Just seen this new pdf and i'm a lil concered, i thought your able to place the meterbar LEDs anywhere on the dout chain - not just after the vpot rings...My design has the meterleds rings on a sep core, which is also used for the forthcoming MTC digits aswell as a single pot for the maser fader...is this still okay?, as i thought it was from a q i posted a while bak...have i got my wires mixed up - so to speak...or is just an example setup uve posted?Best...Dan Quote
TK. Posted July 23, 2003 Report Posted July 23, 2003 Yes, you can place the meter LEDs anywhere - damned! thats the problem when the application allows too much options - how to answer a simple question with one sentence when so much variations are possible? :-( You see: under these circumstances the LC documentation will never be finished... ;-)Best Regards, thorsten. Quote
Steven_C Posted July 23, 2003 Author Report Posted July 23, 2003 Thanks Thorsten!I'm just wondering, why my encoders work properly, when in the 13th and 14th SR, it says "db ID_IGNORE, ID_IGNORE ; (in my setup encoders are connected here)"and I never changed this before I built the main.HEX file?in the standard lc application, will the ledrings work straight away without configuring, if I just connect them to the right shift registers?if I connect the ledrings like in the pdf, will they work straight away, or will I have to assign the SR pins in the lc_IO_table? I am using mios 1.2, as the faders go erratic when I try 1.3 (they kind of don't stop at the target position, they keep going!Yes, you can place the meter LEDs anywhere - damned![Your design is like Logic audio... too many options for beginners, but everything possible that an expert needs! When I get time, I will make a step by step webpage on how to build the standard LC, with upgrade options and things... for beginners, maybe with a modular frontpanel or something! Unless someone beats me to it!Thanks Thorsten!If someone else can help, could they please save Thorsten from all the typing? ;) Quote
Steven_C Posted July 25, 2003 Author Report Posted July 25, 2003 don't worry about answering this, (unless it is for others) cos I probably won't fit Ledrings :P Quote
TK. Posted July 26, 2003 Report Posted July 26, 2003 Hi Steve,When I get time, I will make a step by step webpage on how to build the standard LC, with upgrade options and things... for beginners, maybe with a modular frontpanel or something! Unless someone beats me to it! this would be really helpfull! :) Some infos to LEDrings and encoder settings:buttons are "shadowed" by the encoder pins. Means: once you've assigned two pins to an encoder in mios_tables.inc, these pins will not trigger a button function anymore, therefore the appr. button entries in lc_io_tables.inc will never be processed.digital output pins are "shadowed" by LEDring assignments. Means: the shift registers for anodes/cathodes which are assigned to the LEDring handler cannot be used for common LED functions defined in lc_io_tables.inc, since the handler overwrite the values every milisecondBest Regards, Thorsten.FAQMARKER Quote
Steven_C Posted July 31, 2003 Author Report Posted July 31, 2003 :+)thanks Thorsten! That was helpful! Quote
Steven_C Posted August 13, 2003 Author Report Posted August 13, 2003 ID_MBLC_SWITCH_LEDMETER1 switches to the meter mode, but doesn't switch back. So you have to assign at least one additional button to ID_MBLC_SWITCH_LEDMETER0 or use a single button with ID_MBLC_TOGGLE_LEDMETER for a toggle function, resp. ID_MBLC_HOLD_LEDMETER for a shift function can these functions be used to switch the LCD meters into ledring bars on 40x2? (sick of soldering!) Quote
TK. Posted August 14, 2003 Report Posted August 14, 2003 -> ToDo List :)Best Regards, Thorsten. Quote
