upload problem on my cores from mike.
one core doesn't send anything ( no upload request message)
the other one sends is : F0 00 00 7E 40 00 01 F7
but it doesn't seem to receive anything so ...
I began the TESTs
    *  TEST PROG1: Trust Mike :)
    * TEST CORE1: Ok!
    * TEST CORE2:V3
    * TEST CORE3: it doesn't seem to be a problem like this
    * TEST CORE4: indeed RX is only 1V or around 0.2V instead of 5V .....................!
    * TEST CORE5: no prob with gnd
    * TEST CORE6: seems to be ok BUT on out, M+ = M- ..................
    * TEST CORE7: 1N4148 is correctly placed
    * TEST CORE8: Ok too for the resistor at midi out
    * TEST CORE9: ok
    * TEST CORE10: ok
    * TEST CORE11: that C5 has contact with the +5V/Ground rails (see also mbhp_4xsid_c64_psu_optimized.pdf)!
    * TEST OUT1: Ok with a led but lighted up everytime with a little blinking effect
    * TEST OUT2: ...?!
any ideas before I'll burn all :P
hi lylehaze
my opto is correctly put on the problematic core!
I really don't understand
I'll recheck all the solders on the core to track a short circuit I didn't see...
fortunately, my other core is ok.
mios uploaded.
my 2 DIN are ok, but my DOUT behaves strangely (i don't know if it comes from my led matrix or my dout itself: a line seems to be always on, but with a very little luminance... strange)
I have to check the ain.
I think I had to make my own modules PCB
a big pcb with cores, ain, din, dout, double sided, with vynil coat
I'm sure my problem comes from bad soldering on the one sided modules &/or wires...
grrrrrrrrrrr
You seem to have a lot of intermittent errors, proto. Earlier in the chat you mentioned that your PSU stopped working, the other core (which now mysteriously works) didn't even send out an upload request, ...  Try and focus on one thing at a time.
you are right nils, but it was my first day plugged with protodeck and i just was afraid by thé beast and its behaviours ;-)
so today is a cold head day... better to check without thinking to drop the whole stuff into thé sea...!
i have to check further the core2. probably the short circuit that cause my psu to sleep a bit had just...killed it!
the Core 1 is ok
upload works, etc
Ain & Din are ok :-)
dout or code that drives it doesnt light leds matrix correctly
i'm using an uln on the first SR like noofny did.
the code is : http://code.assembla.com/protodeck/subversion/nodes/protodeck/protodeck_CORE_1/main.c
but it doesnt work
i suspected my matrix but it is ok after checking it
firmware has to respond to midi notes by lighting leds but in order bypass this part, i hardcoded values of ledmatrix storage table...all the same.
any ideas or suggestions?
