tongenerator Posted September 29, 2009 Posted September 29, 2009 Hello,i have a question please.is it possible to use the aditional Trigger Outputs of the Core without havinga for example Analog Out NG or so connected?How much Voltage is comming out of the Trigger?thanks
nILS Posted September 29, 2009 Posted September 29, 2009 Yes, that's possible (depending on the app you want to use it might mean some coding [for the mbCV for instance the amount of coding = 0]), the triggers are 5V
tongenerator Posted September 29, 2009 Author Posted September 29, 2009 it toke me a while to install the compiler stuff and so on... i use openSuse... now i do have headake, loljust one more question about the *.asm file. is there anything else to change? i just want to try the J5 trigger Output within the Seqeunzer 3thanks;; use PORTA and PORTE (J5 of the core module) as trigger output;; NEVER USE THIS TOGETHER WITH ANALOG POTS - IT WILL CAUSE A SHORT CIRCUIT!#define DEFAULT_ENABLE_J5_GATES 1
