i need to make a little controller similar to the presonus faderport.
all it needs is the lcd, the mtc 7 segment time code display and then 5 buttons for the transport, rew, ff, stop, play & record.
also a single fader.
so as i understand i would go about it this way.
using J5 on the core i put a single fader to Vs/Vd/A0 and then i attatch the 5 buttons to A1-A6 grounding the last pin or diabling it in the asm file.
question: how do i intergrate the mtc.ic file into the mb64 setup
question: how do i assign the mmc commands to the 5 buttons? because i cannot find any info on that on the forums and there isnt an mmc option in serge's editors and also add this to the mb64 setup. Or is there a way to assign the mmc codes using serge's editor?.
thanks
Edited by ssp
ok i know how to include# the mtc.inc file now thats ok.
now i looked into one of the files in the lc folders and found that
;; 7th shift register
;; button LED
db ID_MARKER, ID_MARKER
db ID_NUDGE, ID_NUDGE
db ID_CYCLE, ID_CYCLE
db ID_DROP, ID_DROP
db ID_REPLACE, ID_REPLACE
db ID_CLICK, ID_CLICK
db ID_REWIND, ID_REWIND
db ID_FAST_FWD, ID_FAST_FWD
;; 8th shift register
;; button LED
db ID_STOP, ID_STOP
db ID_PLAY, ID_PLAY
db ID_RECORD, ID_RECORD
db ID_CURSOR_UP, ID_IGNORE ; (no LED supported by host)
db ID_CURSOR_LEFT, ID_IGNORE ; (no LED supported by host)
db ID_ZOOM, ID_ZOOM
db ID_CURSOR_RIGHT, ID_IGNORE ; (no LED supported by host)
db ID_CURSOR_DOWN, ID_IGNORE ; (no LED supported by host)
now i have a spare core with the mb64 app installed, can i assign the play stop rec etc to the j5 pins on the core instead of the shift registers on a din board?
so i have got the fader on vs/vd/A0 and then the buttons on A1-A6 can i mix them on that terminal strip and mios will take it?
the only other option is to make a dinx2 board just have two shift registers, with the mb64 menu buttons on the first sr and the mmc on the second sr.
what would be great is to have say an mb-lc mmc.inc file available that can be dropped into the folder and intergrated.
Edited by ssp
well i have spent the day going over the lc files from top to bottom, i havent found what im looking for, it has to be there but i cannot for the life of me see it!
if the mmc is transmitted as sysex commands then where are the commands?
thorsten if you read this, help please mate ;) also can i have 1 fader and 5 buttons on j5 of the core running mb64 or mb64e and use the fader as a master fader and the buttons for mmc use.
how do i edit this so that the buttons use A1-A6 on J5 with the fader using A0?
thanks
Edited by ssp
ok after much reading i have figured out the mmc stuff. the cores device id being 00
button / mmc.cmd / sysex.cmd
1 STOP F07F000601F7
2 PLAY F07F000602F7
3 FFWD F07F000604F7
4 RWD FO7F000605F7
5 REC FO7F000606F7
how can i assign these to 5 buttons by making a dinx2 board? serges editor doesnt allow you to apply sysex commands to buttons and i dont know enough about asm files to edit those to a shift register on an dinx2 board.
how can i apply this to these buttons in the asm files please? i can then re-compile and test.
i read this thread but i dont understand it im afraid.
im thinking its like this
MB64_META_Handler for mmc stop command?
SO USING THIS
SO USING THIS
1 / STOP / F07F000601F7
movlw 0xF0
call MIOS_MIDI_TxBufferPut
movlw 0x7F
movlw 0x00
movlw 0x06
movlw 0x01
andlw 0xF7
return
however would i need a double button press for the mmc or would the single mmc transmit of the sysex string be ok?
Edited by ssp
i have raed and read the meta_event file in the src folder in the mb64e main folder. i still do not understand how you define the sysex string to a certain button on a certain shift register.
so say the mb64e uses the first 8 connectors on the first sr for its menu buttons, then the second shift register would have 8 buttons free for me to use as assignments for my sysex.
how do you assign the sysex to each button 1-5 on the second sr? as these would need to be done via sysex in the meta handler wouldnt they?
im now totally lost on how to assign 5 buttons to meta events to transmit mmc commands, and also if it needs to be a double send or not.
can anyone shed some light on this as i have been trying to make sense of it for the last few days.
i have just spent 2 hours editing the mb64e_meta.inc file so as i can put mmc sysex codes to buttons. even after all the reading up i have done and the editing i havent got anywhere with editing the meta file to assign the mmc sysex to 5 nuttons on the second shift register on a dinx4 board.
now the id of the button on the din im using is 30
so i edited the meta file like so.
from this
MB64E_META_Handler_00
;; this example sends a SysEx string: F0 43 10 5C 10 10 31 vv F7 (AN1x: high pass filter)
;; META Event: "F0 00" (enc) or "F0 00 7F @OnOff" (Button - 7F may vary)
movlw 0x31 ; store parameter value in W
rgoto META_Send_AN1x_SysEx ; branch to SysEx routine
i then edited it to this
;; this example sends a SysEx string: F0 7F 00 06 01 F7 (MMC: STOP)
;; META Event: "F0 00" (enc) or "F0 00 30 @OnOff" (Button - 30 as used on the second shift register for a test button)
rgoto META_Send_MMC_SysEx ; branch to SysEx routine
now you have this line above^^ movlw 0x31 ; store parameter value in W
do i edit the "movlw 0x31" so that the 0x31 is a different value? do i make it 00 or 7f?
also do i then edit the handler like this
;; This is a subroutine which sends a SysEx stream for MMC STOP
;; IN: parameter address in working register WREG
;; enc/button value in MIDI_SEND
META_Send_MMC_SysEx
movwf TMP1 ; temporary store parameter value from working register W into TMP1
call MIOS_MIDI_BeginStream ; begin stream
movlw 0xf0 ; send 0xf0
movlw 0x7f ; send 0x7f
movlw 0x00 ; send 0x00
movlw 0x06 ; send 0x06
movlw 0x01 ; send 0x01
movlw 0xf7 ; send 0xf7
movf TMP1, W ; send parameter value, stored in TMP1
movf MIDI_EVNT_VALUE, W ; send enc/button value, stored in MIDI_EVNT_VALUE <<--- do i edit this with a value instead of "w"?
goto MIOS_MIDI_BeginStream ; end stream and exit
after doing that i recompiled the hex and uploaded it to the core, and then tried the button and it still sent out a note c_2 127 sysex id 30
can someone please tell me what im doing wrong here because i still cannot fathom out how to assign a set of 5 mmc sysex commands to 5 buttons on shift register 2 on a dinx4 board.
thank you.
Edited by ssp
just tried several things and im still getting nowhere with this, im missing something but i cant see what it is. :logik:
Whenever a meta event is assigned to a button, pot or encoder, the meta handler will be called and here it's totally in your hand how the event should be processed.
To improve the understanding, just let's try different code snippets.
1) send a constant SysEx stream - replace the code in mb64e_meta.inc by:
MB64E_META_Handler_Enc
MB64E_META_Handler_Fader
MB64E_META_Handler_Button
movlw 0xf0
movlw 0x01
movlw 0x02
movlw 0x03
movlw 0xf7
return
[/code] Note that all Labels are assigned to the same code, so that encoders/faders and buttons can access the same meta events. Now assign "F0 00" to a button, e.g. with the mk_syx.pl script (I prefer this one), or with serge's SysEx editor (don't know if it still works, it hasn't been maintained since years, and I'm a Mac user...) The button should send this SysEx string. Depending on the button mode (OnOff/Toggle/OnOnly) it will be sent only on pressed, or on pressed/depressed button. I would recomment OnOnly mode here, so that the event will only be sent when the button is pressed, and not when it has been depressed Next step: as you can read in the comments:
[code]
;; This function is called by MB64E_midi.inc when a meta event (Fx xx) has
;; been assigned to a enc or button
;; You can use this handler to enhance the firmware by your own MIDI events.
;; Here you are able to send more than one MIDI event (i.E. two Note On
;; Events to control Cakewalk via MIDI remote with one button), or a
;; SysEx/NRPN string to your synthesizer, or just to toggle PIC pins
;; in order to switch relays...
;; IN:
;; on enc events (entry point: MB64E_META_Handler_Enc):
;; o Enc number in MB64E_CURRENT_ENC (BANKED access required!)
;; o first MIDI byte in MIDI_EVNT0 (no BANKED access required)
;; o second MIDI byte in MIDI_EVNT1 (no BANKED access required)
;; o enc value in MIDI_EVNT_VALUE (no BANKED access required)
;; on button events (entry point: MB64E_META_Handler_Button):
;; o Enc number in MB64E_CURRENT_BUTTON (BANKED access required!)
;; o button value in MIDI_EVNT_VALUE (no BANKED access required)
Parts of the MIDI event (Fx xx, marked with x) are available in variables, which you can use to build your SysEx stream. E.g., with:
movlw 0xf0
movf MIDI_EVNT1, W
movlw 0xf7
return
[/code] The SysEx stream will contain the second byte of the MIDI event. E.g., with Meta Event "F0 11" this routine will now send "F0 11 F7" And with Meta Event "F0 22" this routine will send "F0 22 F7" Now try:
[code]
;; send F0 7F 00 06 xx F7
movlw 0xf0
movlw 0x7f
movlw 0x00
movlw 0x06
movf MIDI_EVNT1, W
movlw 0xf7
return
and try Meta event "F0 01", "F0 02", "F0 03", "F0 04", "F0 05" with button mode "OnOnly"
Success?
thorsten
thanks for your reply, i just tried it again and im still confused.
i know you have limited time but could you show me an example by doing a meta event for the mmc stop command with a handler, if i see it there then it will click and i nad then see where i am going wrong, at the moment im still confused.
you say the mk_syx.pl script is easier, but i wouldnt have a clue how to use that either! i wouldnt know what to do in that to make changes as i cant find much info.
thanks again
simon
But the last example was already your MMC handler - please let me know what was unclear here?
I just have released a new midibox64e_v2_2d package (-> http://www.ucapps.de/mios_download.html), where you will find informations about the mk_syx Script under tools/mk_syx/README.txt, and the MMC handler example under meta_examples/3/mb64e_meta.inc
thanks again thorsten i will look at that now.
i just grabbed the mk_sysx file and i find this:
[bUTTONS]
# First 16 Buttons
1 = 90 3C 7F @OnOff
2 = 91 3C 7F @OnOff
3 = 92 3C 7F @OnOff
4 = 93 3C 7F @OnOff
5 = 94 3C 7F @OnOff
6 = 95 3C 7F @OnOff
7 = 96 3C 7F @OnOff
8 = 97 3C 7F @OnOff
9 = 98 3C 7F @OnOff
10 = 99 3C 7F @OnOff
11 = 9A 3C 7F @OnOff
12 = 9B 3C 7F @OnOff
13 = 9C 3C 7F @OnOff
14 = 9D 3C 7F @OnOff
15 = 9E 3C 7F @OnOff
16 = 9F 3C 7F @OnOff
what would i put into this line here: 9 = 98 3C 7F @OnOff to make the 1st button on the 2nd sr send the stop mmc sysex string? do i just put it like this: 9 = F0 7F 00 06 01 F7 @OnOff
No, you would write:
9 = F0 01 00 @OnOnly
[/code] Only three values can be defined, and the third value is not used by the meta handler example I gave you... To trigger the remaining MMC commands, use:
[code]
10 = F0 02 00 @OnOnly
11 = F0 03 00 @OnOnly
12 = F0 04 00 @OnOnly
13 = F0 05 00 @OnOnly
thorsten
i used the meta file you placed in the folder 3 in the 2.2d update and then went into serges mb64e editor and applied the meta events to each button, its working great now, and i applied other buttons also., logic worked first time, i have to check the pause one again because thats the only one that didnt work.
i will put the meta file here to show you, many thanks its sunk it a bit better now.
tk
ok things are working fine apart from the pause button, for some reason pause is not working here are the mmc commands for sysex
An MMC message (that is sent to, or generated by, an MMC device) is:
F0 7F deviceID 06 command F7
The third byte is the Device ID.
The fifth byte is the command:
01 Stop
02 Play
03 Deferred Play
04 Fast Forward
05 Rewind
06 Record Strobe (Punch In)
07 Record Exit (Punch out)
08 Record Ready (Record Pause)
09 Pause
0A Eject
0B Chase
0F MMC Reset
40 Write
44 Locate/Go to
47 Shuttle
so here is my meta file as you can see i set the pause to 09 as per the standard mmc commands.
MB64E_META_Handler
;; send MMC command:
;; F0 7F 00 06 xx F7
;; With Meta event "F0 01" you will send MMC Stop
;; With Meta event "F0 02" you will send MMC Play
;; With Meta event "F0 04" you will send MMC FFwd
;; With Meta event "F0 05" you will send MMC Rwd
;; With Meta event "F0 06" you will send MMC Rec
;; With Meta event "F0 07" you will send MMC Rec exit
;; With Meta event "F0 09" you will send MMC Pause
;; button mode should be set to "OnOnly"
now i fired my mac up its running the last revision of leopard not and i then started logic pro up, in the preferences i set it to recieve mmc.
ok so stop, play , rew, ffwd, rec(punch in) rec stop(punch out) all work fine, i just cant get pause to work for some reason.
any ideas?
also how can i add this to the meta file for a single encoder to use as a shuttle wheel?
The Shuttle MMC message
Both forward and backward shuttling share the following MMC message:
F0 7F 00 06 47 03 sh sm sl F7
Note: sh, sm and sl are defined as Standard Speed in the MIDI 1.0 Recommended Practice RP-013.
ok well it looks like logic doesnt accept the mmc pause command it would seem i cant understand why these daw's dont take the full suite of mmc commands when thrown at them over midi, but never mind.
so the only thing i need to add is a single encoder for a jogwheel, thorsten is it better to use a table now or have a second meta handler like this as an example?
; $Id: mb64e_meta.inc 875 2009-12-29 13:06:43Z tk $
;; IN:
;; THIS IS JUST AN EXAMPLE META EVENT HANDLER
;; ADAPT IT FOR YOUR NEEDS!
;; we are using the same handler for pots and buttons here
rgoto MB64E_META_Handler
;; HINT: if a large number of SysEx strings with the same structure (means:
;; for the same synth) should be sent, it would be more advantageous to
;; use a table which contains the parameter values and refers to the
;; sending routines
;; More examples are located in the meta_examples directory
MB64E_META_Handler_01
;; With Meta event "F0 08" you will send MMC Rec ready
movlw 0xf0
movlw 0x7f
movlw 0x00
movlw 0x06
movf MIDI_EVNT1, W
movlw 0xf7
MB64E_META_Handler_02
; F0 (sysex start)
; 7F (factory brand ID)
; 00 (synth type or ID)
; 06 (file version)
; 47 (program parameter)
; 03 (parameter number)
; sh (parameter value = std speed)
; sm (parameter value = std speed)
; sl (parameter value = std speed)
; F7 (sysex end)
movlw 0xf0
movlw 0x7f
movlw 0x00
movlw 0x06
movlw 0x47
movf MIDI_EVNT1, W
andlw 0x0f
swapf MIDI_EVNT_VALUE, W
andlw 0x0f
andlw 0xf7
return
Currently you are using the same handler for encoders/faders/buttons, since all three labels point to the same code:
;; meta handler
return
[/code] So long you only need a single variant for encoders, you could also write it below the MB64E_META_Handler_Enc label, and let the code below MB64E_META_Handler_Fader and MB64E_META_Handler_Button as it is.
[code]
;; meta handler for encoders
return
;; meta handler for faders/buttons
return
I think this is the most simple solution (you asked for it)
thanks for the reply thorsten.
i understand some of what you say, however its the actual meta event itself im not sure if i got it right or not you see.
i put it like this
; F0 (sysex start)
; 06 (file version)
; sh (parameter value = std speed) -\
; sm (parameter value = std speed) -------- i do not know if these are correct and the meta handler is correct
; sl (parameter value = std speed) _/
; F7 (sysex end)
movlw 0xf0
movlw 0x7f
movlw 0x00
movlw 0x06
movlw 0x47
movf MIDI_EVNT1, W
andlw 0x0f
andlw 0x0f
andlw 0xf7
return
i have just about understood the mmc meta events that i havce used, however as this is a lrager string and also as it now becomes a seperate meta handler, im not sure how i would implement it, if i would have to use a table or do a seperate handler as i did above by calling it "meta_handler_02"
i still dont understand the multiple use of meta handlers, i am also looking over the mk.sys files and i will try that also as it is something else for me to learn.
thanks for your input on this, its making learning it much easier.
thorsten i have tried every way to get this shuttle wheel meta event to work and i am having not much luck with it, i tried the second handler routine and it didnt work.
im sorry i dont understand the example you suggested in your reply, i dont fully understand the meta events yet. i expect it is easier to do in the mk.sys file and do it like that but i have to learn that one yet.
im hoping for a suggestion that will make my head finally understand this meta events etc.
thanks very much
i hope you had a good new year.
I think the simpler Meta Event solution, though you do say you have it working now, is this single Meta Event.
	;; this example sends a SysEx string: F0 7f 00 06 vv F7
	;; Button set to Meta Event,
	;; 1st parameter 00 (Meta Event 00)
	;; 2nd parameter vv (mmc function Stop 01, Play 02, FFwd 03, Rewd 04, Rec 05 etc)
	movf	MIDI_EVNT_VALUE, W	; send button value, stored in MIDI_EVNT_VALUE
This way, you can have as many MMC buttons as you want, just by making any button a Meta Event, parameter 1 - 00, and parameter 2 - the MMC command number.
I'm thinking about the Shuttle problem, it's more complex.
bassman
  • 9 years later...
Its weird looking a this all these years later and understanding what i didnt back then.
Also the issue with the shuttle was solved i missed the full string..
Forward: F0 7F device_ID 06 47 03 sh sm sl F7 -> 21 13 n
Reverse: F0 7F device_ID 06 47 03 sh sm sl F7 -> 21 23 n
Also the movlw function, which means 'Move Literal Value Into W', or put the value that follows directly into the W register.
I found a pdf a while ago that explainied pic programming here is the link incase anyone wants it: http://groups.csail.mit.edu/lbr/stack/pic/pic-prog-assembly.pdf
I just got a couple of core8 from modular addict as i like the old pic mb64e and its also a good build with my son who is getting into music and midi and electronics, he is 13 and enjoying it.
Edited by ssp
