Software Upgrade
napierzaza
It's been a long time since I built my Midibox SID, and a while since I've been on these boards! So hello to everyone again.
So, I want to update to MIOS 1.9g and get RC35 going on my MBSIDv2. I currently am running RC25 on MIOS1.9f
I haven't tackled rebuilding my application HEX, and I'm hung up on uploading MIOS!
I have my UNO working perfectly considering I see the upload message when the SID starts, and I can send keyboard commands from MIOS Studio and it plays the notes.
However, I can't successfully upload the PIC18f4685.hex file.
The force reboot does not work, and if I just reboot my SID while it's waiting for an upload request it outputs the following
Starting upload of mios_v1_9g_pic18f4685.hex
Hex file contains code in MIOS range, forcing reboot for upload via 1st level bootloader!
The reboot request will lead to an error acknowledge, please ignore!
Waiting for upload request...
Received SysEx message of less than 8 bytes
Does anyone have any recommendations to get this uploaded? EDIT: Here are the messages I receive when the SID boots up
Continued SysEx: F7 0E 00 00 00 00 00
00000001760026 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000001776426 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000001963043 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000001983634 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002042289 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002137388 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002293904 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002507214 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002534072 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000002593462 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000005431912 ms | Continued SysEx: F7 0E 00 00 00 00 00
00000008894189 ms | Continued SysEx: F7 0E 00 00 00 00 00
I suppose it doesn't receive it, or all of it considering it's below 8 bytes, and MIOS Studio appears to think that's strange!
I'm using the CAProvider.jar library for Max OS X 10.6.whatever.
I wonder if I might try another provider of JAVA-Midi it could work? Could it be some strange electrical problem when I boot up the MIDIBox?
Maybe I have two problems
1- On Boot up - Upload request is garbled somehow
2- While booted up - MBSid does not receive reboot request.
But this is somewhat strange since it clearly receives notes and plays audio.
Edited by napierzaza
Well not much has changed. I opened the case and unplugged everything from the unit. The first thing that happened were a few messages sent from the box when the banksticks had been removed. But that seemed normal enough and it was still sending "less than 8 bytes". One thing I noticed was that the two following codes appeared when I didn't have the sid or the LCD plugged in. I never got them before. Does anyone know what they mean? Should I just go ahead and replace the PIC?
00000452089592 ms | [F8] Timing clock
00000452098852 ms | [FF] System Reset
Entire Log:
00000451834989 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451846504 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451861362 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451872615 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451880952 ms | [FE] Active Sensing
00000451880953 ms | [FF] System Reset
00000451880958 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451882233 ms | [B0 79 00] Channel 1: CC Reset All Controllers value: 0
00000451882233 ms | [B0 7B 00] Channel 1: CC All Notes Off value: 0
00000451882233 ms | [B1 79 00] Channel 2: CC Reset All Controllers value: 0
00000451882233 ms | [B1 7B 00] Channel 2: CC All Notes Off value: 0
00000451882233 ms | [B2 79 00] Channel 3: CC Reset All Controllers value: 0
00000451882233 ms | [B2 7B 00] Channel 3: CC All Notes Off value: 0
00000451882233 ms | [B3 79 00] Channel 4: CC Reset All Controllers value: 0
00000451882233 ms | [B3 7B 00] Channel 4: CC All Notes Off value: 0
00000451882233 ms | [B4 79 00] Channel 5: CC Reset All Controllers value: 0
00000451882233 ms | [B4 7B 00] Channel 5: CC All Notes Off value: 0
00000451882233 ms | [B5 79 00] Channel 6: CC Reset All Controllers value: 0
00000451882233 ms | [B5 7B 00] Channel 6: CC All Notes Off value: 0
00000451882233 ms | [B6 79 00] Channel 7: CC Reset All Controllers value: 0
00000451882233 ms | [B6 7B 00] Channel 7: CC All Notes Off value: 0
00000451882233 ms | [B7 79 00] Channel 8: CC Reset All Controllers value: 0
00000451882233 ms | [B7 7B 00] Channel 8: CC All Notes Off value: 0
00000451882233 ms | [B8 79 00] Channel 9: CC Reset All Controllers value: 0
00000451882233 ms | [B8 7B 00] Channel 9: CC All Notes Off value: 0
00000451882233 ms | [B9 79 00] Channel 10: CC Reset All Controllers value: 0
00000451882233 ms | [B9 7B 00] Channel 10: CC All Notes Off value: 0
00000451882233 ms | [BA 79 00] Channel 11: CC Reset All Controllers value: 0
00000451882233 ms | [BA 7B 00] Channel 11: CC All Notes Off value: 0
00000451882233 ms | [BB 79 00] Channel 12: CC Reset All Controllers value: 0
00000451882233 ms | [BB 7B 00] Channel 12: CC All Notes Off value: 0
00000451882233 ms | [BC 79 00] Channel 13: CC Reset All Controllers value: 0
00000451882233 ms | [BC 7B 00] Channel 13: CC All Notes Off value: 0
00000451882233 ms | [BD 79 00] Channel 14: CC Reset All Controllers value: 0
00000451882233 ms | [BD 7B 00] Channel 14: CC All Notes Off value: 0
00000451882233 ms | [BE 79 00] Channel 15: CC Reset All Controllers value: 0
00000451882233 ms | [BE 7B 00] Channel 15: CC All Notes Off value: 0
00000451882234 ms | [BF 79 00] Channel 16: CC Reset All Controllers value: 0
00000451882234 ms | [BF 7B 00] Channel 16: CC All Notes Off value: 0
00000451914995 ms | [F8] Timing clock
00000451915000 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451935959 ms | [FE] Active Sensing
00000451935965 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451937431 ms | [B0 79 00] Channel 1: CC Reset All Controllers value: 0
00000451937431 ms | [B0 7B 00] Channel 1: CC All Notes Off value: 0
00000451937431 ms | [B1 79 00] Channel 2: CC Reset All Controllers value: 0
00000451937431 ms | [B1 7B 00] Channel 2: CC All Notes Off value: 0
00000451937431 ms | [B2 79 00] Channel 3: CC Reset All Controllers value: 0
00000451937431 ms | [B2 7B 00] Channel 3: CC All Notes Off value: 0
00000451937431 ms | [B3 79 00] Channel 4: CC Reset All Controllers value: 0
00000451937431 ms | [B3 7B 00] Channel 4: CC All Notes Off value: 0
00000451937431 ms | [B4 79 00] Channel 5: CC Reset All Controllers value: 0
00000451937431 ms | [B4 7B 00] Channel 5: CC All Notes Off value: 0
00000451937431 ms | [B5 79 00] Channel 6: CC Reset All Controllers value: 0
00000451937431 ms | [B5 7B 00] Channel 6: CC All Notes Off value: 0
00000451937431 ms | [B6 79 00] Channel 7: CC Reset All Controllers value: 0
00000451937431 ms | [B6 7B 00] Channel 7: CC All Notes Off value: 0
00000451937431 ms | [B7 79 00] Channel 8: CC Reset All Controllers value: 0
00000451937431 ms | [B7 7B 00] Channel 8: CC All Notes Off value: 0
00000451937431 ms | [B8 79 00] Channel 9: CC Reset All Controllers value: 0
00000451937431 ms | [B8 7B 00] Channel 9: CC All Notes Off value: 0
00000451937431 ms | [B9 79 00] Channel 10: CC Reset All Controllers value: 0
00000451937431 ms | [B9 7B 00] Channel 10: CC All Notes Off value: 0
00000451937431 ms | [BA 79 00] Channel 11: CC Reset All Controllers value: 0
00000451937431 ms | [BA 7B 00] Channel 11: CC All Notes Off value: 0
00000451937431 ms | [BB 79 00] Channel 12: CC Reset All Controllers value: 0
00000451937431 ms | [BB 7B 00] Channel 12: CC All Notes Off value: 0
00000451937431 ms | [BC 79 00] Channel 13: CC Reset All Controllers value: 0
00000451937431 ms | [BC 7B 00] Channel 13: CC All Notes Off value: 0
00000451937431 ms | [BD 79 00] Channel 14: CC Reset All Controllers value: 0
00000451937431 ms | [BD 7B 00] Channel 14: CC All Notes Off value: 0
00000451937431 ms | [BE 79 00] Channel 15: CC Reset All Controllers value: 0
00000451937431 ms | [BE 7B 00] Channel 15: CC All Notes Off value: 0
00000451937431 ms | [BF 79 00] Channel 16: CC Reset All Controllers value: 0
00000451937431 ms | [BF 7B 00] Channel 16: CC All Notes Off value: 0
00000451958771 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451963776 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451966556 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451981284 ms | Continued SysEx: F7 01 00 00 00 00 00
00000451996859 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452010544 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452016523 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452018297 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452032276 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452054145 ms | [FF] System Reset
00000452054151 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452069318 ms | [FF] System Reset
00000452069327 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452084616 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452089598 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452096711 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452105569 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452109932 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452117678 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452127829 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452132088 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452136293 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452137976 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452145539 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452148085 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452157241 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452160796 ms | [FF] System Reset
00000452230028 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452237745 ms | Continued SysEx: F7 01 00 00 00 00 00
00000452261530 ms | Continued SysEx: F7 01 00 00 00 00 00
Whew,
Apparently I was doing something wrong with my GM5 last night or something. I switched back to my UNO this morning and am receiving constant upload requests.
BUT THEY'RE STILL BELOW 8 BYTES!
WTF?
Okay, for some reason this is what happened. CAProvider wasn't working. What I was seeing is perhaps Apple's halfhearted MIDI java implementation. It is apparently truly half-hearted considering it was eating half of the upload message, even when it was a new burned PIC which was sending lots and lots of requests.
So, anyway, I installed plumstone (rebooted) and not even that worked, so I installed MMJ and now suddenly I have two versions of my UNO appearing in MIOS studio. I hooked up the new one in the routing and it uploaded.
