Hello,
I was thinking about building one since the 1st time i found ucapps about 6 months ago, but due to lack of time/money i postponed this. But starting next month, i want to build one... i only have some (noob) questions for you guys.
I want to build something similar to this one:
Forum Link:
Complete pic: http://www.alphazone1.com/midibox/midibox-complete1.jpg
What kind of rotary pots, sliders, buttons and LED's do i need? I saw a big list on Farnell and I got confused.
What other things do i need ?
What is the cheapest place to buy them from? And.. could anyone tell me (from their own experience)the total amount of money needed for a MidiBox 64?
Thanks.
Welcome aboard, ANdrw :flowers:
70% of your questions are answered in the first thread you linked to. 29% percent are answered on ucapps.de.
The last 1% is this:
Depending on what you have in your spare parts drawer and where you wanna go somewhere between 0€ and 42,000,000€. With the box you linked to I am guesstimating 400-500€.
Back once again..
So, here's what i want to build..
A controller with 4 faders, 17 rotary pots, 20 buttons (4 of them like push to mute/un-mute for example, and the rest simple ones), 8 LEDs for mute/un-mute, (not sure about this yet) one display, and one off/on button
Please help me with parts list... here's what i figured out so far:
1 Core Module
2 AIN Modules
2 DIN Modules
1 DOUT Module
4 Faders
17 Rotary Pots
21 Buttons
8 LEDs
1 Display (maybe!)
Is this list correct? Do I need anything else? Except for the case obviously :)
Thanks
* Do you want potentiometers or encoders?
* You do want the display. It's really nice to have a display for debugging purposes, and generally helpful after debugging.
* 20 buttons -> 1 DINx4 module
* 17 + 4 = 21 analog inputs -> 1 AINx4 module
* 8 digital outputs -> 1 DOUTx1 module (get a DOUTx4 for expandability)
* You also need a power supply
More LEDs are generally nice for more visual feedback, too. Throw together a mockup of the panel, that'll help us find possible problems a lot easier :)
edit: fixed DIN/DOUT typo mixup
Posted (edited)
Thanks for the reply nILS. I got the mockup for the panel ready.
Here's a picture, and below, some explaining of what they mean :)
From top to bottom:
Brown(ish) circle: Larger rotary pot (that i'll probably use for main software output)
Pink rectangle: Off/on switch
Orange rectangle: Display
16 Dark grey rotary pots (mapped for eqs and stuff)
Red: 16 Buttons (that i'll map to trigger samples, etc)
Green: Mute/Un-mute buttons
Blue: LEDs (one will be on while green button is down/one will be on while green button is up) - 2 colors for LEDs
Grey Vertical lines are the faders. But im sure you figured that out by now :)
You asked something about potentiometers/encoders. I think i want potentiometers. They are able to send MIDI data, right? I dont know what encoders are... could you please explain?
It's not the most original deisgn, i know... but it suits my workflow :)
Oh, and the power supply too
Edited by ANdrw
Posted (edited)
Hey ANdrw,
everything you connect to your midibox will send midi data. buttons, encoders, pots/faders.
You could even connect a methane detector to it, so that it will send midi data when someone in the room farts.
pots/encoders:
=encoder&s[]=pot#what_s_the_difference_between_potentiometers_sliders_motor_faders_and_encoders]wiki
Edited by SLP
* 8 digital outputs -> 1 DINx1 module (get a DINx4 for expandability)
I believe you'll find that a DOUT module will drive those outputs with a better response time. :)
Have Fun,
LyleHaze
Guest
Reply to this topic...
