sealion Posted June 23, 2010 Report Share Posted June 23, 2010 I have a happening sammichSID running with presets downloaded and all buttons running, but it does not seem to be stereo. the rca headphones have sound only on one channel. I have swaped the chips with just one chip, the sound does show up in either channel depending on socket. I'm thinking this means a dead chip? Bought from a reliable supplier. Or is there anything eelse to check? Second question I assume the three lower buttons are assignable, how do i do that? Third question what combos does shift work with? The lack of a sammichSID user manual (or even a two pager cheat sheet/pdf has me a bit baffled as much of what i read seems to be for Midibox but not sammichSID. Quote Link to comment Share on other sites More sharing options...
nILS Posted June 23, 2010 Report Share Posted June 23, 2010 I deleted the other (identical) thread. If one of your SIDs works in both sockets and the other doesn't work in either one - one of them is dead. If your seller is reliable he'll probably replace the broken one - unless you broke it :ahappy: Shift-combos/Documentation: the sammichSID is a regular MIDIbox SID v2, so the MIDIbox SID v2 user manual is what you're looking for. Quote Link to comment Share on other sites More sharing options...
phunk Posted June 23, 2010 Report Share Posted June 23, 2010 . Or is there anything eelse to check? You´re aware of the fact that only one of the jacks on the backside of the Sammich is an output jack while the other one is an audio Input? It´s not a left mono output and a right mono output. That means you need a stereo 2 two mono plugs to get stereo sound. :-) just in case you missed that. Quote Link to comment Share on other sites More sharing options...
Wilba Posted June 23, 2010 Report Share Posted June 23, 2010 sealion: You have a dead SID. Get a replacement. This should be no trouble, I know who you got them from, but if it is, email me. Quote Link to comment Share on other sites More sharing options...
