  • 2 weeks later...
very cool, the external controller! would you like to show some pics from inside?
and how did you wire it?
Yay, I'll make some pictures! The wiring is simple... since you just need to connect a DINx2 to the core, you need only 5 wires. A MIDI plug has just the right number. So I basically connected the DINx2 which is in the "joypad" to the DIN connector on the core. All connections to buttons and encoder are inside the joypad. (The orange cable is a piece of network (ethernet?) cable.)
Guest
Reply to this topic...
