Hi
I'm trying to porting a MIOS application wrote in C to ASM. All work just done but i need an help on this:
In my hardware I'm using a 2 position switch on an AIN unmuxed and it is working good with C allowing it to assume only value 0 or 127.
I'm not able to translate in ASM.
My C code ( in pot section ) is:
			// Only allow value 0 or 127
			this_value = this_value < 63 ? 0 : 127;
			// If valid, send CC out
			MIOS_MIDI_TxBufferPut(0xb0);
			MIOS_MIDI_TxBufferPut(53);
			MIOS_MIDI_TxBufferPut(this_value);
Any help to make the same thing in ASM under the section USER_AIN_NotifyChange?
In this moment I'm using the mios_table.inc for specify the midimessages of the pots.
thank you very much.
Dexter
considered that bit #6 will be set on values >= 64, you could write:
movlw 0xb0
call MIOS_MIDI_TxBufferPut
movlw 0x53
movlw 127
btfss this_value, 6 ; bit 6 is set on values >= 64
movlw 0
[/code]
Btw.: you split the range between 0..62 and 63..127, but it's better to split it at 64, since it's exactly the half of the value range.
Hi Tk and thank you for your suggestion.
Is not possible for me to compile with the code you gave me because MPLAB return to me with this error:
MAIN.ASM 289 : Symbol not previously defined (this_value)
something like the "this_value" not recognize...
This is the entire code ( related to pot section)
        JUMPTABLE_2BYTES 2        ; (2 entries because in this trying we use only 2 unmuxed AIN)
        rgoto        Function_for_WREG_00 ; AIN 0
        rgoto        Function_for_WREG_01 ; AIN 1
    rgoto AIN_END
    rgoto AIN_END
    rgoto AIN_END;
    rgoto AIN_END;
    rgoto AIN_END
    rgoto AIN_END
Function_for_WREG_00		; 0-127_AIN 0
    movlw   0xb0
    movlw   0x53
    movlw   127
    movlw   0
Function_for_WREG_01		; 0-127_AIN 1
    movlw   0xb0
    movlw   0x54
    movlw   127
    movlw   0
AIN_END
I can't understand where's the error...
Thank you very much!
Bye
Dexter
The assembler tells you exactly what the problem is: It doesn't know what "this_value" is supposed to be, as it's not defined anywhere (in the C code it must be defined somewhere). Instead of "this_value" you have to use the address(es) where the AIN values are stored.
