Echopraxia Posted September 2, 2010 Posted September 2, 2010 (edited) Hello, Can some one help me with changing the CS_MENU_DIN_TABLE on the MBFM for getting the row buttons on another DIN board. I can't get the interrupt service routine working and just want to use a second DIN board instead of going in to the DOUT for these buttons. Here is the table CS_MENU_DIN_TABLE ;; Function name SR# Pin# DIN_ENTRY CS_MENU_BUTTON_Dec, 1, 0 ; only valid if rotary encoder not assigned to these pins DIN_ENTRY CS_MENU_BUTTON_Inc, 1, 1 ; (see mios_tables.inc) and CS_MENU_USE_INCDEC_BUTTONS == 1 DIN_ENTRY CS_MENU_BUTTON_Esc, 1, 2 DIN_ENTRY CS_MENU_BUTTON_Sel1, 1, 3 DIN_ENTRY CS_MENU_BUTTON_Sel2, 1, 4 DIN_ENTRY CS_MENU_BUTTON_Sel3, 1, 5 DIN_ENTRY CS_MENU_BUTTON_Sel4, 1, 6 DIN_ENTRY CS_MENU_BUTTON_Sel5, 1, 7 DIN_ENTRY CS_MENU_BUTTON_Sel6, 2, 0 DIN_ENTRY CS_MENU_BUTTON_Sel7, 2, 1 DIN_ENTRY CS_MENU_BUTTON_Sel8, 2, 2 DIN_ENTRY CS_MENU_BUTTON_Cfg, 2, 3 DIN_ENTRY CS_MENU_BUTTON_InsOP1, 2, 4 DIN_ENTRY CS_MENU_BUTTON_InsOP2, 2, 5 DIN_ENTRY CS_MENU_BUTTON_InsOP3, 2, 6 DIN_ENTRY CS_MENU_BUTTON_InsOP4, 2, 7 DIN_ENTRY CS_MENU_BUTTON_InsOPSel, 3, 0 ;; the M_Row[1234] buttons are handled from an interrupt service routine! DIN_ENTRY_EOT ; ========================================================================== ; This short table lists the SR/pin numbers of the four ; Matrix Row Select Buttons. ; Since these buttons are multiplexed (4 DOUT pins -> 1 DIN pin) to save ; one DIN shift register, we have to define the DIN pin and 4 DOUT pins ; which are connected to these buttons (see also schematic) ; ========================================================================== DIO_M_COL_ENTRY MACRO sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3, sr4, pin4, sr5, pin5 db (pin0 + 8*(sr0-1)), (pin1 + 8*(sr1-1)), (pin2 + 8*(sr2-1)), (pin3 + 8*(sr3-1)), (pin4 + 8*(sr4-1)), (pin5 + 8*(sr5-1)) ENDM DIO_M_ROW_ENTRY MACRO sr_in, pin_in, sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3 db (pin_in + 8*(sr_in-1)), (pin0 + 8*(sr0-1)), (pin1 + 8*(sr1-1)), (pin2 + 8*(sr2-1)), (pin3 + 8*(sr3-1)) ENDM DIO_M_TABLE ;; --> DIN <-- pins of the 6 column select buttons ;; Col1 SR/Pin, Col2 SR/Pin, Col3 SR/Pin, Col4 SR/Pin, Col5 SR/Pin, Col6 SR/Pin DIO_M_COL_ENTRY 4, 2, 4, 3, 4, 4, 4, 5, 4, 6, 4, 7 ;; --> DOUT <-- pins of the 6 LED columns ;; Col1 SR/Pin, Col2 SR/Pin, Col3 SR/Pin, Col4 SR/Pin, Col5 SR/Pin, Col6 SR/Pin DIO_M_COL_ENTRY 2, 6, 2, 7, 3, 0, 3, 1, 3, 2, 3, 3 ;; --> 1*DIN/4*DOUT <-- pins of the 4 row select buttons ;; DIN SR/Pin, Row1 SR/Pin, Row2 SR/Pin, Row3 SR/Pin, Row4 SR/Pin DIO_M_ROW_ENTRY 3, 1, 2, 2, 2, 3, 2, 4, 2, 5 ; ========================================================================== ; The following table defines all available DOUT pins with the appr. ; register and bit which is assigned to the pin ; CS_MENU_LED_Update uses this table to update all LEDs ; ; The register name and bit number can be found on the left, ; the shift register and pin number on the right side. ; ; SR/pin numbers: ; SR = 1 for the first DOUT shift register ; SR = 2 for the second DOUT shift register ; ... ; SR = 16 for the last DOUT shift register ; ; Pin = 0 for the D7 output pin of the shift register ; Pin = 1 for the D6 output pin of the shift register ; ... ; Pin = 7 for the last output pin (D0) of the shift register ; ; Set the SR and pin number to 0 if a LED function should not be used ; ; The table must end with DOUT_ENTRY_EOT! ; ========================================================================== DOUT_ENTRY MACRO reg, bit, sr, pin dw reg, bit | ((pin + 8*(sr-1)) << 8) ENDM DOUT_ENTRY_EOT MACRO dw 0x0000, 0x0000 ENDM CS_MENU_DOUT_TABLE ;; Register and bit SR# Pin# Description DOUT_ENTRY CS_MENU_SELECTED_INS_FLAGS, 0, 1, 0 ; INS1 LED (Note: Pin #0 is the D7 output of first SR) DOUT_ENTRY CS_MENU_SELECTED_INS_FLAGS, 1, 1, 1 ; INS2 LED DOUT_ENTRY CS_MENU_SELECTED_INS_FLAGS, 2, 1, 2 ; INS3 LED DOUT_ENTRY CS_MENU_SELECTED_INS_FLAGS, 3, 1, 3 ; INS4 LED DOUT_ENTRY CS_MENU_SELECTED_OP_FLAGS, 0, 1, 4 ; OP1 LED DOUT_ENTRY CS_MENU_SELECTED_OP_FLAGS, 1, 1, 5 ; OP2 LED DOUT_ENTRY CS_MENU_SELECTED_OP_FLAGS, 2, 1, 6 ; OP3 LED DOUT_ENTRY CS_MENU_SELECTED_OP_FLAGS, 3, 1, 7 ; OP4 LED DOUT_ENTRY TMP1, 0, 2, 0 ; Instrument LED DOUT_ENTRY TMP1, 1, 2, 1 ; OP LED ;; NOTE: the pins of the MIDI Rx/Tx LEDs are assigned at main.asm DOUT_ENTRY_EOT Edited September 2, 2010 by Echopraxia
Echopraxia Posted September 2, 2010 Author Posted September 2, 2010 So I am looking at the DIO_M_ROW_ENTRY ;; --> 1*DIN/4*DOUT <-- pins of the 4 row select buttons ;; DIN SR/Pin, Row1 SR/Pin, Row2 SR/Pin, Row3 SR/Pin, Row4 SR/Pin DIO_M_ROW_ENTRY 3, 1, 2, 2, 2, 3, 2, 4, 2, 5 What do I need to change to define only the 4 pins on a new DIN SR. I would do DIN SR 5 PIN 0,1,2,3. Do I just delete The ;; --> 1*DIN/4*DOUT <-- Column and also delete the first entry which was labeled DIN SR/Pin like this? ;; --> DIN <-- pins of the 4 row select buttons ;; Row1 SR/Pin, Row2 SR/Pin, Row3 SR/Pin, Row4 SR/Pin DIO_M_ROW_ENTRY 5, 0, 5, 1, 5, 2, 5, 3 Or do I add it to the first Din column below DIO_M_COL_ENTRY ?
nILS Posted September 4, 2010 Posted September 4, 2010 Like TK already said. Fix it at hardware level. Period.
