vic20 sound chip?
Does it use same (or similar)as C64?I wasted 1 hour of time trying to find this info.
Just use the search function of this forum:
Search for: vic20
Max Age since last post: 300
...here some SID-Info I found:
6581 is the "old version" SID
8580 is the "new version" SID
You'll find SID inside of the C64 + C128
There is no SID inside the AMIGA or VIC20
C64 (Brotkasten) => SID 6581
C64c (or C64-II) => SID 8580
C128D => SID 6581
C128 DCR => SID 8580
Source: http://cbmmuseum.kuto.de
Greetings
- Lemonhorse
i was not thinking about finding a SID inside an AMIGA, but about the possiblity of biulding something like SID MIDIBOX with the sound chip found in AMIGA (who was better than the sid, if i don't remember bad!)
thanks!!
Guest cem3340
Firstly, Vic 20 sound is very simple squarewave only device (like most early comp sound)
Secondly, the sound produced by Paula chip in Amiga has no comparison with the SID. The SID is a TRUE sound synth. The Paula chip produced its sound by getting the Main CPU to do all the work. The Paula chip is not much more than a multiplexed low end audio DAC (digital to analog converter) So yep, in general the sound produced by it was superior to the SID, BUT the sound produced was either samples or using inbuilt routines within Amiga's OS to generate squarewaves etc.
Correcting my own statements ;)
The statement about the CPU doing all the work is a little misleading. The CPU would shift a block of data into RAM. It would then pass the address pointer of this block to the Paula chip. Paula would then access this wave data and loop or single shot through it via DMA
(direct memory access)
