D. Stephenson Posted September 29, 2010 Posted September 29, 2010 Hi, Since my soldering skills are rather pathetic, I'm guessing it will take a couple months until I can fully build a functioning Core32. In the meantime, will MIOS32 work with the STM32 Discovery kit for software testing? It uses the STM32F100RBT6B chip. Thanks Dave
D. Stephenson Posted September 29, 2010 Author Posted September 29, 2010 I think I answered my own question after taking a look at this and taking a closer look at the specs on the discovery board (128k flash & 8k ram). Although it is possible to port it... the very limited memory on the discovery chip makes it fairly useless to use MIOS32. Even the first tutorial gave me a greater memory usage than the chip can use: 40832 flash (text) 12440 ram (bss) Please let me know if I am wrong, but if not I guess it's time to warm up the soldering iron. Thanks Dave
nILS Posted September 29, 2010 Posted September 29, 2010 I guess it's time to warm up the soldering iron Correct :) Solder some random led-blinker kits or sth and you're good to go. Keep in mind - the stm32 comes pre-soldered, so all you have to do is diy-friendly through-hole stuff.
