I think I answered my own question after taking a look at this and taking a closer look at the specs on the discovery board (128k flash & 8k ram). Although it is possible to port it... the very limited memory on the discovery chip makes it fairly useless to use MIOS32. Even the first tutorial gave me a greater memory usage than the chip can use:
40832 flash (text)
12440 ram (bss)
Please let me know if I am wrong, but if not I guess it's time to warm up the soldering iron.
Thanks
Dave
Correct :) Solder some random led-blinker kits or sth and you're good to go. Keep in mind - the stm32 comes pre-soldered, so all you have to do is diy-friendly through-hole stuff.
