baptistou Posted October 26, 2010 Report Share Posted October 26, 2010 Hi all there, I've been using strtol function for a while in my program without any error. I updated the SVN repository folder on my computer this morning, and now without having changed anything from my program, everytime I compile I get: Creating object file for sentinel.c sentinel.c: In function 'Sentinel_ValidateChecksum': sentinel.c:222: warning: pointer targets in passing argument 1 of 'strtol' differ in signedness Any clue of what's happening in there? Here is the part of my sentinel.c causing these warnings: ///////////////////////////////////////////////////////////////////////////// // this takes a string, and validates it againts the checksum // at the end if the string. // returns 1 checksum OK -1 bad checksum -2 checksum not found in string ///////////////////////////////////////////////////////////////////////////// s8 Sentinel_ValidateChecksum(u8 *strPtr,u32 len) { u8 calculatedChecksum; u8 writtenChecksum[3]; char *next; u8 readChecksum; u8 c; u32 p; calculatedChecksum = Sentinel_GenerateChecksum(strPtr, len); p = 0; c = 0x00; while ((c != '*') && (p < len)) { c = strPtr[p]; p++; } if (p > len - 2) { //DEBUG_MSG("nmea_validateChecksum p > len -2"); return -2; } writtenChecksum[0] = strPtr[p]; writtenChecksum[1] = strPtr[p+1]; writtenChecksum[2] = 0x00; readChecksum = strtol(writtenChecksum, &next, 16); if (readChecksum == calculatedChecksum) { //DEBUG_MSG("nmea_validateChecksum checksum OK"); return 1; } //DEBUG_MSG("S-- wrong checksum (read %x calculated %x)\n", readChecksum, calculatedChecksum); //DEBUG_MSG("%s \n", strPtr); return -1; } Quote Link to comment Share on other sites More sharing options...
nILS Posted October 26, 2010 Report Share Posted October 26, 2010 Seems like the compiler is complaining that your string is u8* = unsigned char* while it's expecting char* (default would be signed iirc). Why don't you just do sth like readChecksum = (strPtr[p]-48)*10 + (strPtr[p+1]-48); and not bother with strtol? Quote Link to comment Share on other sites More sharing options...
baptistou Posted October 26, 2010 Author Report Share Posted October 26, 2010 (edited) Hi nILS, I'm using strtol as it handles hexadecimal values, and my checksum are hexadecimal. I can't see why strtol has changed its behaviour from between the two version of the SVN folder. Also, now that I modified the other files of my project (and the compiler had to rebuild the .o files), I have this error with the function strncpy also everywhere. Has something changed in the declaration of the "u8" "u16" etc. ? It looks like "u8" are not equal to "char" anymore... Baptistou Edited October 26, 2010 by baptistou Quote Link to comment Share on other sites More sharing options...
nILS Posted October 26, 2010 Report Share Posted October 26, 2010 I'm using strtol as it handles hexadecimal values, and my checksum are hexadecimal. Well, it would be fairly easy to adjust my example to that ;) Has something changed in the declaration of the "u8" "u16" etc. ? It looks like "u8" are not equal to "char" anymore... u8 has never been char. Afaik, it's always been unsigned char. Quote Link to comment Share on other sites More sharing options...
baptistou Posted October 26, 2010 Author Report Share Posted October 26, 2010 I agree I could easily add a function converting strings to hexadecimals. I didn't take care before today that u8 was unsigned while char is, but I don't understand why I didn't have any warning before updating my SVN folder. Anyways, how do I pass an unsigned variable to a function requiring a signed one? Quote Link to comment Share on other sites More sharing options...
nILS Posted October 26, 2010 Report Share Posted October 26, 2010 By type-casting it. Quote Link to comment Share on other sites More sharing options...
philetaylor Posted October 26, 2010 Report Share Posted October 26, 2010 I am guessing that you always had the warnings but the compiler didn't bother to tell you before :) One of the recent changes that TK has made is add -Wall to the global CFLAGS (in $MIOS32_PATH/include/makefile/common.mk) This causes GCC to enable ALL warnings (including signed/unsigned mismatch) which makes debugging easier especially as a signed char can only store a 7 bit value (positive or negative) whereas unsigned is 8 bit positive only and the difference can lead to all sorts of problems !!! Cheers Phil Quote Link to comment Share on other sites More sharing options...
TK. Posted October 26, 2010 Report Share Posted October 26, 2010 It's great to have such warnings. E.g., in MBSEQ I had to fixed 100s of warnings (took ca. 1 hour), but I found a potential bug which could happened in the past due to function calls with incomplete parameter list (-> random behaviour) I never noticed this before as I forgot to include the header file into the .c code -> accordingly the C compiler allowed me to pass any parameter w/o producing an error about an "undeclared function" or "inappropriate usage". Due to this experience I decided to enable warnings for everybody. Sorry for the inconvenience - you would really like the change if it would have warned you about *THE BUG* that infrequently happened in the past and that you never reproduced during long debugging sessions before. ;) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
baptistou Posted November 15, 2010 Author Report Share Posted November 15, 2010 Thanks guys, as a newbie I do agree to say that warnings are definitely useful: they teach you how to code properly! Best regards, Baptistou Quote Link to comment Share on other sites More sharing options...
