Technosoul Posted November 20, 2010 Posted November 20, 2010 Ok So, I am at the stage of the build, got my 12v regulated power supply - tested voltage - all good. Installed IC, load mios - installed banksticks and sids - sound good. I am not getting any functions from buttons and knob. LCD works fine. Now, the mistake I did make was put the 6 pin Common bus resistors in backwards - I took them out adn re installed the right way (way to go), check voltage, all is good - still no response from buttons and knob. Can you advise please. thanks. Man just when things were going so smooth and bhaaaa, had to make some sort of mistake.
Technosoul Posted November 20, 2010 Author Posted November 20, 2010 i crack myself up, found my problem IC in wrong slot. Thanks for your help. I hope any one reading this by passes this mistake
Technosoul Posted November 20, 2010 Author Posted November 20, 2010 I just loaded the patches - I just wanted to give a shout out to TK and who ever else helped make those patches - super sick. this machine is raw. And wilba sick sickness on the sammich - very fun build. I look forward to diving into this machine and understanding its features better. you guys rock
