Hey there,
It's me again. No panic, it seems to be everything fine. No SID toast action or something else ;)
But after some time I recognized, that one channel is a little bit louder than the other : ~1dBfs.
It's normal ? I checked the soldering points of the resistors : all ok.
My SID types :
8580 R5 - 3988 25
8580 R5 - 3588 25
Maybe the tolerance of the resistors or the different types of SIDs are the problems?
If I don't know if it's normal or not, I have no ambitions to solder out the caps or trans and replace then.
I have the problem in Stereo and mono mode. I test it with the InitialPatch.
... and, no. I think it's not a user error :
I use LineIn channels on my interface, so no preamp differences. I tested 4 pairs of line-in channels, everytime the same problem.
AND ... I test another interface.
And no, the software/channel-strip is configured right.
SO I think it's the sammich.
Thanks for your help, again.
Greetz,
Tom
Edited by Duke64
I try to delay the swap-action ...
But jeah you are right : the problem are the SIDs.
Now, I regret to crashed my matched pair of 6581.
But hey, this is the old cool shit and this is the reason, we love this things :ahappy:
I correct the level inside of my DAW and all fine.
I try to delay the swap because I'm afraid to damage the SIDs (I think you know why).
But after Fellmings post I do the swap (I hope the last time in my life).
The louder channel changeover from left to right >> SIDs sound different.
Do you belive in crystal balls anymore ? :sorcerer:
