yodabe Posted December 30, 2010 Report Posted December 30, 2010 hi all alps STEC12E07 are compatible with the mbfm ? http://be01.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=623-4221 i tryed on my mbfm but not work corectly (work corectly on my mb64e) only one way work (inc) i tryed few encoder no change checked and rechecked the pcb nothing wrong try another din module not change only inc grrrrrrr try switch for testing the routing its ok ! ? sorry for my bad english best regards yod@
Hawkeye Posted December 30, 2010 Report Posted December 30, 2010 Hi, how did you connect them? Middle PIN=GND, left and right pins go to two different DIN pins? I am using the STEC12E08 (with push button) and they work flawlessly (using DETENTED3 setting for MIOS). Methinks the STEC12E07 is just a 08 without push button and should work therefore... Bye, Peter
TK. Posted December 30, 2010 Report Posted December 30, 2010 It's probably a wrongly configured encoder type. MB64e uses MIOS_ENC_MODE_NON_DETENTED while MBFM uses MIOS_ENC_MODE_DETENTED2 by default. According to Peter MIOS_ENC_MODE_DETENTED3 is the more suitable one for STEC12E0x Yod: do you already know how to change the setup_mbfm_v1.asm file and recompile the application? (see also README.txt) Best Regards, Thorsten.
yodabe Posted December 30, 2010 Author Report Posted December 30, 2010 Hawkeye Hi, how did you connect them? Middle PIN=GND, left and right pins go to two different DIN pins? i tested the gnd pin is A not middle TK Yod: do you already know how to change the setup_mbfm_v1.asm file and recompile the application? (see also README.txt) yep i compiling for detented3 not work ! one way trying detented1 yessss is ok !!! bye best regards
Hawkeye Posted December 30, 2010 Report Posted December 30, 2010 (edited) The different pinout is interesting... thanks for your feedback. edit: I looked at the datasheet: http://www2.produkti...R_STEC12E07.pdf on page 5 it says that "C" is the middle pin and on page 3 you can see that "C" is "ground" and is switching pins "A" and "B", when the knob is turned. So this is somehow strange - but if it works for you - never change a running system ;-) Edited December 30, 2010 by Hawkeye
