Rocker Switch in the Sammich
phunk
Dont you have canibalized c64´s ? :X
You can use the ones from the c64.
From the notes of Wilbas dokuwiki: #
The switch S1 is the same switch as found in a Commodore 64. You can temporarily use any DPDT switch until a good supply of these switches is located. The DPDT rocker switch from Mountain Switches which was previously suggested (http://www.mouser.com/catalog/specsheets/MS-100818.pdf) does not suit the rearpanel design.
greetz
