Ok, I've been sick the last few days (there's a flu lurking around)
and to make good use of my spare time I decided to whip out my Sammich (it's been in storage since I moved a couple of months ago)...
First of all;
The voltage readings are fine (all of them).
The sammichCSTest.hex worked fine (all the LEDs lit up like in Wilba's little flash video).
The OS uploads/installs fine.
I could even transmit the vintage presets to the Sammich (and I see the name of the first patch).
But none of the buttons work.
Strange, eh?
Help a brother out!
(ps. I only have one 6581 installed, shouldn't matter and I've got a perfect regulated 12V PSU)
Edited by Geir_Helgi
First, I'd check the traces connected to the shift registers (74HC165) and the solder points.
If you could make some close-up pictures I could check the it visually.
So, it worked before or what??
And the encoder works??
I once experienced that my CS did not work at first power-up, but then i quickly remebered that i didn't solder the header pins on the CS, only for the LCD :wacko:
Edited by Flemming
Ok, I'll check those traces..
The only dodgy things on the board (lower board) are the heat-sink solder joints,
because I messed it up and had to use the upper surface points.
It wouldn't hurt to know what the continuity/ohm meter should read on that part of the pcb :rofl:
It didn't work before,
the encoder doesn't work either and none of the buttons work :sad:
Both headers are soldered.
  • 3 years later...
WOW!
Just found my old sammichSID which wasn't working, resoldered some nasty newbie mistakes and thorougly checked all the points (according to the build guide)
Still nothing happened :(
Then I found an old thread where somebody (like me) was so eager to get his SID sound up & running that he accidentally put some ICs in the wrong place!!
I checked those and *bam* there was the problem that had me running in circles all that time :D
Now I'm sending an arpeggiator into my Sammich (with a 6581) and it sounds GREAT :D
Can't wait to start using it, loving it and tweaking it :D
Thanks everyone!
Happy 2014!
