padjoe.thornton Posted April 4, 2011 Report Posted April 4, 2011 Hi again Total newb here but I'm nearly there just installed sid 8580 .hex but I'm only getting a flashing lcd screen saying launching cs I just can't find anything about this on the site thank you
Param1 Posted April 4, 2011 Report Posted April 4, 2011 I am a Noob myself so I can just give a general tip. I found 2 problems by closely looking at http://www.midibox.org/dokuwiki/lib/exe/fetch.php?hash=a55f1b&media=http%3A%2F%2Fwww.mb6582.org%2FsammichSID%2FsammichSID_Base_PCB.pdf and measuring / continuity testing my board.
Altitude Posted April 4, 2011 Report Posted April 4, 2011 Fast flash or slow flash? Sounds like something is sucking too much current for the supply u are using
padjoe.thornton Posted April 5, 2011 Author Report Posted April 5, 2011 (edited) Hi again Thanks for your replys After TK's kind help in an earlier question regarding the midi connector I was using, I uploaded MIOS with just the Core module connected, I then connected two sids and 1 bankstick And uploaded the midibox_sid_v2 hex file and worked fine It then rebooted and I got a screen flashing the Sid application name to Launching CS, sid app name to launching CS .....on and on The flash wasn't too fast, but it wasn't slow either Like it was trying to load but something was preventing it? It wasn't switching on and off. Has this happened to anyone before? Thanks PJ 2 x 8580 sids 1 x core 1 x bankstick 2x20 LCD screen To be connected to minimum control surface Edited April 5, 2011 by padjoe.thornton
