Rave-TZ Posted May 29, 2011 Report Posted May 29, 2011 My mixer is out of inputs :p I have things I need to add, but my 8 channel MIDIBOX is eating most of the available space. What is the best approach to get a clean stereo output from all 8 SID chips? Quote
m00dawg Posted May 29, 2011 Report Posted May 29, 2011 (edited) The MIB-6582 uses a passive mixer, a design which I melded together with the CMoy audio amp design. You can find my (untested) work on the =sidr8tr]wiki. It probably works as it should but I haven't reached that phase of my synth build yet so use at your own risk. You need a bipolar supply, but I was going to have one anyway in my design since I was wanting to use analog filters as well. Edited May 29, 2011 by m00dawg Quote
Hawkeye Posted May 30, 2011 Report Posted May 30, 2011 For me the passive mixing in the mb6582 works very fine, i don´t even need amplification when going into an ordinary mixer with 2 channels. Quote
