Posted (edited)
Hi
I'm building my first MB project, a stereoSID
CORE and SID modules working, LCD working
buildt DINx4 module from SmashTV and minimal CS
DIN not working
nothing happens when I press buttons or turn encoder
what I've tried:
-checked for shorts/bad solders on DIN and CORE, OK
-tested cable between CORE and DIN, OK
-tested button press by connecting VS and different pins on DIN with cable, still nothing happens
-uploaded MIDIO 128, connected pins, still nothing
-reinstalled MIOS and SID V2, no change
any suggestions anyone?
SOLVED
I have a 5 pin cable going from J9 on CORE to J1 on DINx4
I thought it should connect to the 5 pins closest to the SR's
obviously wrong, cause when I moved it everything worked :)
Edited by eptheca
Posted (edited)
Hi
- checked all 10 PCB bridges (are they all existent)?
- checked all digital inputs (Button pressed: 0V, Button depressed +5V @ D0 to D7)?
SOLVED :-)
Edited by lemonhorse
Especially stupid posts shouldn't be removed to avoid that other people are doing the same stupid errors.
(and this happens more often than doing unstupid errors! ;)
