eptheca Posted May 30, 2011 Posted May 30, 2011 (edited) Hi I'm building my first MB project, a stereoSID CORE and SID modules working, LCD working buildt DINx4 module from SmashTV and minimal CS DIN not working nothing happens when I press buttons or turn encoder what I've tried: -checked for shorts/bad solders on DIN and CORE, OK -tested cable between CORE and DIN, OK -tested button press by connecting VS and different pins on DIN with cable, still nothing happens -uploaded MIDIO 128, connected pins, still nothing -reinstalled MIOS and SID V2, no change any suggestions anyone? SOLVED I have a 5 pin cable going from J9 on CORE to J1 on DINx4 I thought it should connect to the 5 pins closest to the SR's obviously wrong, cause when I moved it everything worked :) Edited May 30, 2011 by eptheca
lemonhorse Posted May 30, 2011 Posted May 30, 2011 (edited) Hi - checked all 10 PCB bridges (are they all existent)? - checked all digital inputs (Button pressed: 0V, Button depressed +5V @ D0 to D7)? SOLVED :-) Edited May 30, 2011 by lemonhorse
eptheca Posted May 30, 2011 Author Posted May 30, 2011 I know this look stupid, but I didn't find a way to delete the post
TK. Posted May 30, 2011 Posted May 30, 2011 Especially stupid posts shouldn't be removed to avoid that other people are doing the same stupid errors. (and this happens more often than doing unstupid errors! ;) Best Regards, Thorsten.
