hydre Posted June 14, 2011 Posted June 14, 2011 hello all, I was wondering where I can get potentiometers that "stop" in the middle. What I mean is like on dj mixer eq knobs, when you are on the middle position, there is a something that stops it so you can turn the pot quickly and you feel where the middle is. Anybody know the name of this type of pot and where I can get it? I might need it for a traktor mixer controller. Thanks, I hope that was clear enought
jojjelito Posted June 14, 2011 Posted June 14, 2011 (edited) Hiya! What you want is potentiometers with mid-point detent. Take a peek in the relevant pages at Digi-Key or Mouser. Search for potentiometer, then refine to say 9mm PCB-mounted, and load the relevant page that's suggested when looking at one of them. Now have fun matching the article numbers with actual inventory :sorcerer: Capisce? If not I'll give you an example later. Cheers! Edited June 14, 2011 by jojjelito
hydre Posted June 14, 2011 Author Posted June 14, 2011 Hey thanks for the term ! I'll have a look thanks again!!
hydre Posted June 14, 2011 Author Posted June 14, 2011 mmmm, I only found this one for now but I think it is logarithmic: My link If anyone has a part number that they have used I'd be interested
jojjelito Posted June 14, 2011 Posted June 14, 2011 (edited) Take some time and narrow down what you want in terms of mounting, resistance and type of shaft. I've used various depending on which type of project, enclosure etc. I don't know which method of mounting you would prefer, but going by the datasheet I wanted something vertical with bushing or sleeve so EVJ-Y96 and -Y91 was searched for. Produit non stocké - merde! Digi-key is easier - Search for EVU-F3L for single pots (cheat by looking at the datasheet!) and you'll get to select between Lin (control, balance) and Log (audio). Aha, not fun, you can get 5k, 20k, 50k so if you absolutely must have 10k you are SOL with Panasonic. What next - try Alpha (or TaiwanAlpha), Alps or Bourns. Go to pots and start narrowing things down - 10K, single turn, 6mm axle (actuator dia) and top adj. Select in stock. Now you're down to some 16 choices. Compare type against datasheets - oh the fun! Go with EVU-F3M and never look back. Or something. Double: EVJY-81, 91 or 96. Pick for instance the nice metal bushing EVJ-Y91F03B14 and never look back. You want another shaft (knurled or some non-metric dia)? Change the search params, rinse and repeat. Mouser: Do the keyword Alps and narrow it down. You'll end up looking (a lot!) at the datasheet for the RK09 and RK12L series. Same with Alpha: RV141F (with clear shaft for some LED fun) or... Now you know why people get minor headaches when sourcing components! Take a peek here: Mouser catalog page for Alpha or here for some Bourns love. Sorry if this sounds complicated, there are lots of choices out there for sure. And you have to iterate your search. Good luck! Edited June 15, 2011 by jojjelito
julienvoirin Posted June 14, 2011 Posted June 14, 2011 (edited) i advise you to get the same as those used on Pioneer mixers (sorry don't know the ref) : they are in metal and D shaft east oriented the panasonic's center detent ones used in x0xb0x are too soft Edited June 14, 2011 by julienvoirin
jojjelito Posted June 15, 2011 Posted June 15, 2011 (edited) No ref here either, but Alps RK09L (RK09L114001T) with all metal shafts are stiffer. Some Alpha or Taiwan Alpha pots are way stiff, search for those to suit if the Alps is not OK. Edited June 15, 2011 by jojjelito
hydre Posted June 17, 2011 Author Posted June 17, 2011 thanks peeps, that definitly seems like a headache, I think I'll go for normal pots for the first version of the controller, we'll see in july when I really start this thing. thanks again for the help!
CSC Posted June 17, 2011 Posted June 17, 2011 (edited) Here some from german .bay with center detend, linear and 10k ALPS Metal- D- Shaft. http://cgi.ebay.de/20x-ALPS-RK09-Poti-Automotive-10K-lin-Mono-/300563400568?pt=Bauteile&hash=item45faf98778 25mm from Ground to Top, PCB mounted. Shaft 10mm D-Shaft length: 7mm Really Good POTS! Edited June 17, 2011 by CSC
