Logic Control emu missing functions
Guest squirrelly_dude
hi!
i was working out my layout on my lc and noticed that there were 7 button functions missing and one added.
where did they and how could i add these back?
thanx to everybody for the previous help,
secret squirrel
the functions i noticed  were:
name/value, smpte/beats, save, undo, group, solo, and scrub.
the one added is the layer function.
i don't know if these fuctions are needed or not.  if you could satisfy my couriosity, that would be cool.
p.s. thanx again for setting straight on the mackie ext thing.
btw do you know when the panasonic mf driver will be finished?
squirrel
MIDIbox LC provides some additional functions which are not available on the original, one of this is the "layer" button which switches to another button/LED group. In this way you can save some buttons!
Every group consists of 128 button and LED functions --- see lc_io_table.inc, LC_IO_TABLE_LAYER0 and LC_IO_TABLE_LAYER1, this is the default setup, but of course: you can rearange the events if you want.
You will find the save, undo, group etc. function in the second layer.
thanks tk,
so how about that panasonic mf driver?
It will be available before you've finished your MIDIbox ;-)
Some users like Dan reported that the Panasonic faders are already working fine, some others noticed problems. So I guess that only a minor change (e.g a different acceleration behaviour) will be required. I will try Steve's Panasonic faders after I've finished another project for which users are asking since months - take it easy... sooner or later everything will be perfect.
I've just left the settings as they came in the LC app zip and it'd seemed to work out okay...
Speaking of faders - i stumbled accross these:
http://www.alltronics.com/resistors.htm
They have motorfaders here for only $4.95 and some nice joysticks for $2.95. I've ordered a single MF to test and also a few joysicks :D...i'll report how the fader is when it arrives....
Best
Dan
hi tk,
i just have one more quick question bfore i order the remaining parts.
what about the master volume? i don't need it to be a mf.  is there a way to hook up a fader for this and how?
thanks again for all the help.
squirrel
Since the MF driver allocates all 8 analog inputs of the PIC, and the AINX4 multiplexers cannot be used in parallel with the MF module, the only way is to build a second core module.
thanks Dan,
yeah, mine wouldn't go higher than that either, I had to change one of the resistor values, to get a more useable range, it was a resistor near the voltage regulator and the trimpot somewhere, from memory I think I changed a 100 ohm reisistor to 50 ohms, or something...
