orange_hand Posted November 18, 2011 Posted November 18, 2011 Hi Guys, I have got recently a new sampler, the Octatrack. After I got my hands on for a couple of hours in order to learn the basic functions of this machine I decided to record a short jam session. I hope you like it. http://soundcloud.com/orange_hand/orange-hand-octatrack-vs Cheers orange
TK. Posted November 19, 2011 Posted November 19, 2011 I would like to give you some suggestions for improvements: - add feedback pots to your MB-6582 and enable the EXT filter function - this will result into a more aggressive bassline - switch to the Knobs layer in the oscillator section, so that the most important parameters CutOff/Resonance/EnvMod/Decay/Accent are directly accessible, you should change them more often - is it possible to route the audio output of MB-6582 through the Octatrack and to apply some effects? - (I only played an Octatrack once and therefore I'm unsure but..) is it possible to sample MB-6582 during a session for some beats and thereafter to apply effects on such a sample? Currently it sounds like two different instruments are playing in parallel, but somehow I miss the interaction between the instruments. Add at least a compressor (or limiter) at the end of the audio chain. Best Regards, Thorsten.
orange_hand Posted November 20, 2011 Author Posted November 20, 2011 Hi Thorsten, thanks for your feedback. You are right with your statements, the session is to static overall... There is a lot to improve. I will try to apply your suggestions in the next session... Cheers orange
