johnh Posted February 12, 2012 Report Posted February 12, 2012 After some futzing around I think I successfully loaded the MIOS32 bootloader. I don't have my parts from SmashTV yet so I can't test it (or can I?) so could someone confirm, the LED blinks three times and then goes off and then comes on and stays on. Is this what I should be seeing? Thanks.
TK. Posted February 12, 2012 Report Posted February 12, 2012 Yes, your core module is up&running! Best Regards, Thorsten.
johnh Posted February 12, 2012 Author Report Posted February 12, 2012 (edited) Thanks Tk! Now I'm working to get I've got the board split into two pieces using a 'box-cutter' and multiple passes. Edited February 12, 2012 by johnh
matoz Posted March 6, 2012 Report Posted March 6, 2012 Hi all, i can't load mios32 bootloader, when i click on the icon "program flash", there is nothing inside the box. When i try to open project.bin, computer says it isn't a valid Win32 application. Any idea?
matoz Posted March 6, 2012 Report Posted March 6, 2012 (edited) Some news, i have the file project.bin into the project window, and when i click on the icon program flash, it says: "project project has no MCU information" No problem with the file project.hex, i can be opened, but i didn't found yet how to send it into the board. Edited March 6, 2012 by matoz
matoz Posted March 6, 2012 Report Posted March 6, 2012 yeah!!! it works, the LED blinks three times and then goes off and then comes on and stays on , i think it is ok. In File, i selected New, other, selected LPCXpresso C project, select wizzard C project, named it "test", select target selection LPC1769, and select None in CMSIS options, and it create a project on project window at the left, and after that i was be able to click on the icon program flash, i browse the project.bin and click OK, and it has been done.
