lukas412 Posted February 19, 2012 Posted February 19, 2012 So I feel like this worked for me at some point but it doesn't now. When I'm in the pattern screen and I use GP 1-8 to switch between A-H/a-h I can only select the uppercase letters. Hitting the button twice does not select the lower case letter. Did something change? I'm running the latest version of the sequencer. Thanks, Luke
TK. Posted February 20, 2012 Posted February 20, 2012 For MBSEQ V4 this is normal, since each bank only supports 64 patterns. Create a new session if you need to store more patterns - the number of available sessions is only limited by the size of your SD Card ;-) Best Regards, Thorsten.
lukas412 Posted February 21, 2012 Author Posted February 21, 2012 Ok cool, I have not come close to needing more patterns, just making sure I have everything working properly. Thank you! Luke
