lukas412
Programmer
    269
    2
lukas412 last won the day on July 22 2019
lukas412 had the most liked content!
About lukas412
  • Birthday 02/04/1978
Contact Methods
  • Website URL
    http://www.technoiraudio.com
  • Gender
    Male
  • Location
    Pittsburgh, PA, USA
Recent Profile Visitors
lukas412's Achievements
MIDIbox Tweaker
MIDIbox Tweaker (3/4)
7
  1. Will this work with the e6400 classic? If so I want one.
  2. This one was a bit tricky to search for, but I'm guessing from the manual there is no way to do this. Is it possible to configure CV to play chords?
  3. lukas412
    midiphy MatriX :)
    I can't even express how excited I am for this.
  4. Hello @TK. I was wondering if it would be possible to add additional clock dividers to the analog clock out. Having PPQN is nice, but being able to divide it down further would be really useful for me. In a modular a lot of time I will take 1 PPQN out and send to a clock divider module to create longer intervals. This can be worked around using the trigger out or a gate out but then you loose a track. thanks, Luke
  5. Looking good @TK.! Thanks! Luke
  6. @Rowan and @TK I am having the exact same issue. CV_GATE_SR2 only triggers one time and then stays on. It's not the module as I swapped two of the gate modules and the one connected to CV_GATE_SR1 always works fine. This happens with the latest release. thanks, Luke
  7. I get this as well. I have been working through the problem with Andy, but haven't fully solved it yet. I have pretty much the same setup as @TK (4ms pod) and I get hum. Its much worse than @TK indicated his was, I see about a 20db increase in noise. I also notice that the more step LEDs I light up the louder the noise gets. I'm not even sure its ground hum. The only solution I have found so far is to use a USB cable connected directly to power and not the computer. Everything works great if there is no MBSeq -> PC connection. Another odd note is that it's some how related to the actual USB signal. In one case I was using a USB hub connected to my PC and thought I had solved the problem. Turned out that the USB cable I was using was bad and the hub was only giving the MB power, not actually connecting to the PC. As soon as I replaced it the hum came back again. Luke
  8. How do you configure the clocks? Never mind I found it! In the cv page.
  9. What is the recommended DB-25 cable length? thanks, Luke
  10. Thanks Hawkeye! Just placed my order for the kits!
  11. Ok just started watching the tutorial vid looks like its really accurate!
  12. Has anyone tested out the tracking on these yet? Are they better/worse than previous version of mbcv modules? thanks, Luke
  13. This looks sooo cool! Thank you! Any idea on depth of the modules?
  14. Feature request: Using the Midiphy build In drum mode while Inst is selected flash button for instruments that are playing notes when the note plays.
  15. Here's another one! What a fun build. The engineering is incredible. Thanks to everyone involved!
