dutchbastard Posted March 13, 2012 Posted March 13, 2012 I was thinking of starting a Midibox SID_v2 project, as i need to wait two months on the parts for my current midibox128 project. After research i found out that a good replacement for the original SIDs are the Nano SwinSIDs (http://retro-donald.de/sinchai-shop/index.php?main_page=product_info&cPath=3&products_id=90). However i wanted to recreate the mb_6582, the circuit boards for those are sold on SmashTV's website. I've read that these Nano SwinSIDs are the same size as an regular SID. Am i correct that these will fit perfectly then? Also i've read that for the MBHP_SID the polarised capacitators differ on which SID you use. I guess the Caps on the partlist in SmashTV's shop are the right ones?
Gilesjuk Posted March 14, 2012 Posted March 14, 2012 They just plug in, there's plenty of room between the chips. There's no analogue filter in the SwinSID, so I don't think the filter capacitors are even needed. There's also no audio in, so you can't do the feedback mod. But then the SwinSID has some other tricks up its sleeve.
dutchbastard Posted March 14, 2012 Author Posted March 14, 2012 They just plug in, there's plenty of room between the chips. There's no analogue filter in the SwinSID, so I don't think the filter capacitors are even needed. There's also no audio in, so you can't do the feedback mod. But then the SwinSID has some other tricks up its sleeve. Its not a huge problem there is no audio in for the feedback mod, however if there is no analogue filter in the SwinSID i wont be able to use the LFO and the filter sections? If thats true i guess i'll have to hunt down some old SID chips.
technobreath Posted March 15, 2012 Posted March 15, 2012 The swinsids were supposed to emulate filters no? I thought that it was the lack of analog filters was taken care of firmware wise. I know little about swinsid in general, but it should be a direct working replacement with the limitation that u can't filter external audio, but the internal audio should be just as with the original, only fake hehehe. Where do I get a swinsid? I want to try one out... Or two... I also thought there was a midibox firmware specially aimed towards the use of swinsid. Maybe TK could answer these questions of yours...
dutchbastard Posted March 15, 2012 Author Posted March 15, 2012 The swinsids were supposed to emulate filters no? I thought that it was the lack of analog filters was taken care of firmware wise. I know little about swinsid in general, but it should be a direct working replacement with the limitation that u can't filter external audio, but the internal audio should be just as with the original, only fake hehehe. Where do I get a swinsid? I want to try one out... Or two... I also thought there was a midibox firmware specially aimed towards the use of swinsid. Maybe TK could answer these questions of yours... You can get one in the shop i linked in the first post, however it seems that the shop is down for maintanance? My german isn't very good :(
technobreath Posted March 18, 2012 Posted March 18, 2012 If this thing is compatible with mbhp I will be ordering a bunch soon. They are not spendy at all... Wow.
Gilesjuk Posted March 18, 2012 Posted March 18, 2012 There is analog filter emulation yes. There's only one filter to emulate, so it's not that CPU intensive.
swinkels Posted March 18, 2012 Posted March 18, 2012 Indeed, SwinSID emulates all SID filter modes without need of external capacitors.
Gilesjuk Posted March 19, 2012 Posted March 19, 2012 Makes the build somewhat simpler then :) no 9v or 12v required then?
dutchbastard Posted March 19, 2012 Author Posted March 19, 2012 Thanks for the answers guys :) Time to order some parts
