julienvoirin Posted March 23, 2012 Posted March 23, 2012 (edited) Dear Boxers I need your help, really, as i am not familiar with the electroluminescent (EL) technology I have a Yamaha REV7 with a very old LCD (Hitachi 44780 driver). The backlight is dead. It is not a LED backlight but a sheet of EL material. So i bought a EL sheet on ebay to replace it. When the sheet arrived i tested it by connecting it to the inverter and it has glowed. But the sheet was too big, so I cut it to the good dimensions. But after, the EL was no more glowing (??? wtf !!). I measured the output of the inverter : a pseudo sinusal 150V AC @ 222 Hz 1 - is the inverter dead ? (it transforms 5V DC in 150 AC) 2 - is he EL foil dead ? i cut it with scissors the sheet is similar to this one : http://www.elec2go.com.au/images/el%20cuttbale%20panel%201.jpg inverter is NEL-D32-46 Thanks for your help Cheers :)midiboxYamaha_REV7_Schematic_REV7-F.pdf Edited March 23, 2012 by julienvoirin
Gilesjuk Posted March 23, 2012 Posted March 23, 2012 Do you still have the pads in your design? eg. http://www.compsys1.com/support/docs/ELbacklight_Guide.pdf There are pads that need to remain as part of the foil.
julienvoirin Posted March 23, 2012 Author Posted March 23, 2012 thanks for your prompt answer Gilesjuk :) If i well undertand, you call "pad" what i call electrodes : yes there are still is place, there are 3 groups of electrod on 3 sides so that you can cut the EL foil to fit your design
