Spirit Posted April 13, 2012 Report Posted April 13, 2012 Hello again. I have connect 20 Fader to a AINx4 Maby a little strange but it Used pin 13 to 32. But if i slide the fader on pin 32 in Does not Respont. i if slide the fader on pin 31 it react only it Send 2 notes. And to make a Layout from Pin 32 to 13 it look like this. R = Reponding only it sends 2notes N = Not responding N-R-R-N-R-N-N-R - N-R-R-N-R-N-N-R - N-R-R-N As you see its the same Pattern But what did i do Wrong? Kind regards, Emile ballard Quote
Janis1279 Posted April 14, 2012 Report Posted April 14, 2012 Hi, If you used MB64 setup connection diagramm looks like : http://www.ucapps.de...p/auaimbctg.pdf and asm setup file part looks like: ; Setup File of TK's MIDIbox64 ; ; Number of connected pots ; Allowed values: 1-64 #define DEFAULT_NUMBER_POTS 20 ; number of connected pots ; ; Multiplexers (AINX4 modules) connected? -> set this value to 1 ; No multiplexer connected= -> set this value to 0, allowed number of pots in this case: 1-8 #define DEFAULT_MUX_ENABLED 1 ; enable multiplexers ; Regards, Janis Quote
Spirit Posted April 14, 2012 Author Report Posted April 14, 2012 Hi thanks for the reply i will look in to it. But i just connect the other AINx4 module and that one just works fine. i also connected the wires this time from 1 to 20. so if i get my pots i will try the other AINx4 module again and see what will happin. Thank anyway, and yes i made a MB64. Kind regards, emile ballard Quote
unuldinei Posted May 3, 2012 Report Posted May 3, 2012 1 - Check the CORE with 8 unmuxed pots.If it is OK then ... 2 - Check the board AIN4 , it seems is like a defect on it . Quote
Spirit Posted May 4, 2012 Author Report Posted May 4, 2012 Thats for the extra thinking. but as i sad before the Second AINx4 Module work like a Sharm. but i look a little closer to the other AINx4 module and i Noticed one BIG soldering fault and a Little one. so hopefully that will solve my problem. but first i'm waiting on my Nice Digitast Buttons. then the Pots will come ;-) Thanks for everything, Spirit Quote
