Hello,
i have upgrade my last SID application from rc17 to rc38. Now i want to try out the play function (which has work fine in rc17 with SID1+MenuButton), but it doesn't
work anymore. Is there something wrong with my setup or has something changed in rc38?
thanks for feedback.rio
Hi Rio,
the old mechanism was problematic when the sequencers of multiple SIDs should be synchronized to an external MIDI clock (only a single SID could be played at one time).
Therefore it has been changed (in rc19!)
Relevant entries from the CHANGELOG.txt file:
MIDIboxSID V2 RC19
o The "note off" function of the SHIFT menu now works as "Note On/Off" (called "Ply")
This function is intended as replacement for the optional Play button
Patch will be played/stopped on all selected SIDs
o Removed button combination "SIDx+MENU" (which was previously used for Play function)
This combination could get a different purpose on future
[/code]
