Param1 Posted May 3, 2012 Report Posted May 3, 2012 (edited) Seems like the LCD is about to die. (that's actually the second faulty LCD of 4... I had). What are the specs I need to know to get a replacement ? If you are from Germany, can you show me one please? It should fit to the green LED lamps if possible. (black and white display would be cool too, does not need to have green in it) Thanks :-( Edited May 3, 2012 by Param1 Quote
nILS Posted May 3, 2012 Report Posted May 3, 2012 It's an industry standard sized 2x20 with an hd447800(-compatible) controller. http://www.reichelt.de/index.html?ARTICLE=53948 will fit, the datasheet has all the info you need to find different ones. Quote
